MSB Link DAC I、II、III 差別....
文章阿毛 發表於 週五 4月 13, 2001 4:36 pm
to 阿毛
CS 4396
CS 4397
AD1852
AD1853
PCM1737
PCM1738
PCM1739
.......... 等
熊熊以為你在報明牌:grin:
全世界最窮的發燒友就是我:P
阿毛
文章: 4248
註冊時間: 週二 12月 05, 2000 2:44 am
文章andy236 發表於 週五 4月 13, 2001 4:58 pm
Bel Canto DAC1 FAQ的一段話
http://www.belcantodesign.com/html/p_dacfaq.html
What is the best transport to use with the DAC1?
There are a variety of CD and DVD transports that have been reported to work well with the DAC1. Our experience shows that all transports with well controlled low frequency jitter are the best match with the DAC1.
NOTE: There is sound technical support for why a DVD player works well. All DVD players have a minimum of 16MB of SDRAM used as a buffer in which digital data from the disc is stored. The digital information is then re-clocked out of the buffer. This SDRAM acts as a large FIFO buffer eliminating low frequency jitter that could otherwise affect the sound quality. The combination of well controlled low frequency jitter from the DVD player and the high frequency jitter elimination of the DAC1 creates an ideal jitter reduced environment for a high quality musical presentation
註解中認為DVDPlayer出來的數位訊號還不錯,跟一般的認知好像不同
請大家幫忙解讀一下
苦命的電腦軟體人,還是多聽聽好音樂吧:)
andy236
文章: 1909
註冊時間: 週三 12月 13, 2000 9:46 pm
來自: 天上山下
文章阿毛 發表於 週五 4月 13, 2001 5:29 pm
North Star Model 192 規格
The digital section is based on:
Crystal  CS8420-CS   digital receiver and upsampler to 96kHz-24bit
NPC    SM5849AF   upsampler 96-192kHz
Crystal  CS4396-CS  DAC 192kHz-24bit
單純以規格來說
跟P3A有像
但用的東西高階一點
全世界最窮的發燒友就是我:P
阿毛
文章: 4248
文章阿毛 發表於 週五 4月 13, 2001 5:32 pm
重點似乎是16MB of SDRAM的FIFO buffer
這東西應該是電腦界習慣使用的方式
到底對聲音有哪些影響我就不清楚了:eeh:
全世界最窮的發燒友就是我:P
阿毛
文章: 4248
文章andy236 發表於 週五 4月 13, 2001 5:43 pm
對啊!
FIFO buffer是電腦常用得的東西,先進先出序列的緩衝區
以這邊來說避免轉盤讀取的不穩定(這句是我自己猜的),先讀到SDRAM再re-clocked輸出
這句 eliminating low frequency jitter
可消除 xxx jitter, low 連成一串就不懂了
救命啊,快來人解讀一下:eeh:
Edited by - andy236 on 04/13/2001 18:20:02
andy236
文章: 1909
來自: 天上山下
文章JCP 發表於 週五 4月 13, 2001 7:31 pm
那段英文是說DVD player裡的16MB RAM當buffer用可以消除低頻的jitter,配合他們DA裡面消除高頻jitter的線路,可以把jitter降到最低。
如果buffer這麼有用的話,用電腦就最方便了。
JCP
文章: 1203
註冊時間: 週一 12月 04, 2000 9:28 pm
文章Monster 發表於 週五 4月 13, 2001 10:27 pm
to 阿毛
那個P3A 用CS4397當DAC實在很怪
那顆DAC可以調resolution ....
只是.......
有人會閒閒沒事調回 16bit 工作嗎 ? ....
Monster
文章: 69
註冊時間: 週二 2月 20, 2001 12:19 am
文章阿毛 發表於 週五 4月 13, 2001 11:41 pm
TO Monster
我是蠻喜歡它家老闆的
是個有創意的人物
選用的晶片也蠻非主流的
P3A 用CS4397當DAC真的不知道他原先的想法是什麼
TO fredpeng
還記得您在AB網站談過很多CD-ROM的問題
不知道您覺得FIFO buffer是否有用呢
感謝
全世界最窮的發燒友就是我:P
阿毛
文章: 4248
文章阿毛 發表於 週六 4月 14, 2001 4:44 am
找到點東西
http://www.eyah.com.au/it/netschool/big ... dmt077.htm
節錄相關內容如下
為何讀取電腦用的CD不會讀錯,但是抓取CD音軌時就會有雜音、爆音了呢?首先我們來看看一張CD的容量有多少。一般人的印象,CD的容量是650MB左右。即使您不知道,走一趟電腦店,看看CD-R的刻錄空片,包裝盒上也大都會寫上此容量。接著我們來看看一張CD可以記錄多久的聲音。相信大部分的人都知道一張CD可以記錄74分鐘左右的音樂。根据這個時間,我們來算算看這時候一張CD的容量有多少︰(CD音樂品質為16bit ,44.1Khz,Stereo)奇怪,前面說一張CD是650MB左右,但是經過計算,卻有746MB。到底是多在哪里,又是少在哪里呢? 原來,電腦用的CD,与播放音樂用的CD,在格式上是不同的。一般我們電腦在使用的CD,格式是ISO9660,每一個磁區是2048 bytes,但是音樂用CD卻是每個磁區有2352 bytes。ISO9660所減少的那一部份容量,被拿來作為錯誤修正碼(ECC,Error Correction Code),用來确保當我們讀取電腦用CD時,不會讀取錯誤。所以,Audio CD是沒有錯誤修正能力,讀取錯誤時是不知道的,這就是雜音、爆音產生的基本道理。可是您也雪|問,我听音樂CD的時候,怎仇ㄓㄦ|有雜音?但是自己抓取CD音軌,雜音就產生了呢?這通常出現在高倍速抓取CD音軌的机种。相信大家對于電腦產品會有一种認知,那就是越快的東西可能越不穩,抓取CD音軌也是一樣,當你在播放音樂CD時,是以一倍速(約178KB/s)的速度在讀取CD資料,空虛時候對于CD Player or CD-ROM來說,是中規中矩的作業,可以表現得很好,當然前提是你的CD不要有嚴重的刮痕損傷啦﹛但是高倍速抓取時,就會提高讀錯的可能性,這時候就要看各家CD-ROM的奶O如何,做得好的机种,高倍速讀取也不容易讀錯;做的普通的机种,就錯誤連連,難免產生雜音、爆音了。所以目前有釵h的光驅,雖然標榜自己是24、32等倍速,但是在抓取CD音軌時,几乎都不是使用最高速抓取,最常見的就是降到8至12倍速左右,這就是厂商根据CD-ROM性能的考量,在速度与品質間所做的一种取舍与考慮。
CD-ROM因為在設計上是定線速,所以在讀內圈資料和讀外圈資料時的碟片轉速會不同,讀內圈時會比外圈快得多,而為了要簡化設計,釵hCD-ROM都只是用一個FIFO(First In,First out)的緩衝區來控制轉速,當緩衝區快要滿的時候就將轉速降低,反之則加快,故在讀取資料時的間距就會忽大忽小,這就是jitter。這在讀取資料軌時沒有什什暋D,因為每個資料區塊有起始碼及第三層ECC(error correcting code),但音樂軌時就有問題了,因為在音樂軌的資料中沒有起始碼,無法准确的決定每一個frame的起始位置,所以會有一种現象就是,一片音樂CD中的某一首歌,在兩台CD-Player中播放出來的時間會有一點點差距。為了要解決這种音樂播放時的問題,各家厂商都在CD device里加上一些線路來設法解決問題,這就是de-jitter。當我們要在電腦上利用可以抓音軌的CD-ROM來抓音軌時,一樣會發生這种問題,但因為近來CD device的技術越來越進步,再加上(我猜測的)有些公司的CD-ROM有用到額外通道中的一些信息來确定每個frame的起始位置,因此已經可以做到100%完整重現音樂軌的資料,因為無論如何,de-jitter后所得到的音樂軌資料,很有可能會和原始資料不同,既然在大部份的情形下可能听不出來,但是仔細听還是有些變化比較快的地方是可以听得出來的。
全世界最窮的發燒友就是我:P
阿毛
文章: 4248
文章阿毛 發表於 週二 5月 01, 2001 3:02 am
TO andy236
整理出來了嗎?
全世界最窮的發燒友就是我:P
阿毛
文章: 4248
正在瀏覽這個版面的使用者:Google [Bot], Majestic-12 [Bot] 和 23 位訪客
