E-MU New Driver/PatchMix ver.1.81 10/03/2005
文章oScARSr 發表於 週二 10月 04, 2005 5:35 pm
What's New ?
change log
Driver Package V1.81 contains the following feature enhancements and fixes:
Driver Version# 5.12.1.1103
Feature Enhancements:
* Installer now fully installs Digital Audio System drivers on any machine that meets minimum hardware requirements, including those that do not have previous Digital Audio System software installed.
* Added 88.2 kHz and 176.4 kHz support to products using E-MU 0404, 1212M, 1820 and 1820M PCI hardware. (NOTE: Also requires PatchMix DSP V1.81 or later)
* Added support for up to 8 channels of audio playback through the E-DSP Wave device. This allows the digital audio system to play certain types of multi-channel content (WAVE_FORMAT_EXTENSIBLE format) (NOTE: Also requires PatchMix DSP V1.81 or later)
* Changed buffer latency selection choices in the ASIO Control Panel to offer more granularity at lower latencies
Fixes:
* Fixed bug where hardware latency values displayed in certain ASIO applications (such as Cubase SX 3 and Nuendo) were not accurate.
* Fixed bug where Audio Dock would sometimes not power up properly on a system boot.
E-MU PatchMix DSP version V1.81 contains the following feature enhancements and fixes:
E-MU PatchMix DSP Version V1.81 Feature Enhancements:
* Added Multi-channel WDM playback support for all Digital Audio Systems. (NOTE: Also requires E-MU Digital Audio System Driver Patch 1.81 or later)
* Added Import/Export of Core FX Presets and Multi FX Presets
* Added 88.2 kHz and 176.4 kHz sample rate support to E-MU 0404, 1212M, 1820 and 1820M Digital Audio Systems (NOTE: Also requires E-MU Digital Audio System Driver Patch 1.81 or later)
* Added "Load FX on Startup" option (when disabled, the loading of FX preset data is deferred until first launch of FX Palette.This greatly shortens PatchMix launch time on startup.)
* New temporary session and session saving behavior
Fixes:
* Fixed Application crash that happens when using the "Fast User Switching" feature in Windows XP
* Fixed bug where PatchMix would sometimes show meter activity but no sound would be heard
* PatchMix will now specifically prompt an error if the user creates, deletes or renames FX categories that contain characters that are not legal in the file system.
For E-MU 0404/1212M/1616/1616M/1820/1820M
Get it :
http://www.emu.com/support/welcome.asp?rd=download
Portable : shure se215
oScARSr
文章: 22
註冊時間: 週五 9月 19, 2003 6:57 pm
來自: 中部
文章SEVEN SEAS 發表於 週二 10月 04, 2005 6:20 pm
哪位高手能將重點翻譯一下的嗎
英文實在看不懂 :mad: :mad: :mad:
SEVEN SEAS
註冊時間: 週一 6月 13, 2005 9:02 pm
來自: 台中
文章MIG29 發表於 週二 10月 04, 2005 7:22 pm
剛剛換裝了
感覺音場有大一點點點
可能是心理作用 :ho:
動圈新天際線 GRADO GS1000
MIG29
註冊時間: 週四 6月 05, 2003 9:07 am
來自: 台中市
文章holygod 發表於 週二 10月 04, 2005 8:21 pm
雖然沒有用Emu的卡...不過大致上翻一下 :)
Driver Package V1.81的部份
新功能有
* 會完整安裝數位音訊系統(Digital Audio System)驅動程式
* E-MU 0404, 1212M, 1820 以及 1820M加入了88.2 kHz 以及 176.4 kHz 的支援 (需要
安裝 PatchMix DSP V1.81或之後的版本)
* 支援透過E-DSP Wave裝置播放8聲道音訊,因此可以使用數位音訊系統播放一些多聲道
的格式 (WAVE_FORMAT_EXTENSIBLE格式) (也需要安裝PatchMix DSP V1.81或之後的版本)
* 改變了ASIO控制面板中的緩衝延遲時間選擇(buffer latency selection)以提供較
小單位的低延遲時間可選擇。(這句不確定啦.. :eeh: )
修正的部份:
* 修復在某些ASIO程式中硬體延遲時間值顯示不正確的問題(像是Cubase SX 3 以及 Nuendo)
* 修復開機時Audio Dock不會正常開啟的問題。
E-MU PatchMix DSP version V1.81的部份
功能加強:
* 所有的數位音訊系統(Digital Audio Systems)都支援了多聲道WDM播放(需要安裝E-MU Digital Audio System 1.81版驅動程式更新)
* 加入Core FX預設值以及Multi FX預設值的匯入/匯出功能
* E-MU 0404, 1212M, 1820 以及 1820M的數位音訊系統(Digital Audio Systems)加入了88.2 kHz 以及 176.4 kHz的取樣比支援(也是需要安裝E-MU Digital Audio System 1.81版驅動程式更新)
* 加入了 "開機時載入FX"的選項 (如果停用的話,載入FX預設值時就需要先等待FX Palette啟動。所以這個選項可以減少開機時PatchMix的啟動時間)
* 有新的臨時session以及節省session的方法
修正部份:
* 修復了在使用Windows XP的"快速使用者切換"時的當機問題
* 修復了有時PatchMix的計量板有顯示動作但是卻沒有聽到聲音的問題。
* 如果使用包含非法字元的名稱設定FX類別時,PatchMix會顯示錯誤提示
HD600★W1000★Tannoy Autograph mini★Good Music! ^^
holygod
文章: 9
註冊時間: 週五 8月 09, 2002 2:03 pm
來自: 皆神村
文章ash2459 發表於 週四 10月 06, 2005 12:40 am
剛剛把兩個都升級成1.81版。最大的感覺是新版軟體的聲音比以前柔和。
Alan Hsu
ash2459
註冊時間: 週四 1月 01, 2004 1:53 pm
文章hclin 發表於 週四 10月 06, 2005 12:10 pm
PatchMix和Driver哪一個要先灌啊
是不是PatchMix :x
HD 650
1212m -> KECES DAC1739(OPA637BP) -> KECES HA-711(OPA2132PA)
Kingcable銀IC PC
fullcity數位線
hclin
註冊時間: 週三 3月 19, 2003 1:56 pm
來自: Taipei City
文章windwalker 發表於 週四 10月 06, 2005 12:31 pm
先裝PatchMix , 然後接著灌Driver , 再重開機.
重開機後記得Load回你原本的Session..
windwalker
註冊時間: 週四 10月 10, 2002 1:03 am
來自: 偽裝成台北人的高雄人
文章hclin 發表於 週四 10月 06, 2005 8:04 pm
windwalker 寫:先裝PatchMix , 然後接著灌Driver , 再重開機.
我灌反了
難怪有錯誤訊息
HD 650
Kingcable銀IC PC
fullcity數位線
hclin
來自: Taipei City
文章superpipi 發表於 週四 10月 06, 2005 8:22 pm
我是先灌driver再灌patchmix,沒問題呀? :o
superpipi
註冊時間: 週四 5月 13, 2004 4:12 am
文章windwalker 發表於 週五 10月 07, 2005 9:49 am
hclin 寫:我灌反了
難怪有錯誤訊息
灌反應該是沒差才對啊....
不過這次用舊的Session在新版的PatchMix上有時會有Error...
windwalker
來自: 偽裝成台北人的高雄人
文章oScARSr 發表於 週五 10月 07, 2005 12:51 pm
咦?
我都是先裝driver的...
難怪會死當。 :x
oScARSr
文章: 22
來自: 中部
文章pcvhaha 發表於 週五 10月 07, 2005 3:09 pm
舊的要先移除吧
有點想直接蓋過去.........
pcvhaha
文章: 21
註冊時間: 週六 1月 18, 2003 10:58 pm
文章jefm 發表於 週五 10月 07, 2005 3:46 pm
PatchMix 的下載頁是這麼說的:
Before you install:
*If you have experienced a fault in any audio application, you should reboot Windows before applying this update.
*Exit all applications before installing these updates.
*Installation of Application and Driver can be done in any order.
*This installer will automatically uninstall any older versions of software before installing new version.
Driver的下載頁中也沒有說要先移除 ;)
jefm
註冊時間: 週三 1月 12, 2005 12:00 am
來自: 屏東
文章耗子 發表於 週五 10月 07, 2005 3:57 pm
jefm 寫:PatchMix 的下載頁是這麼說的:
Before you install:
儘管如此…依照「暈倒」系統的慣例
還是先將舊驅動移除來的安全些… :ale:
耗子
註冊時間: 週四 5月 19, 2005 2:43 pm
來自: 耗子窩
文章hclin 發表於 週五 10月 07, 2005 4:14 pm
EMU的檔案要安裝很久
感覺起來是製作很嚴謹的
HD 650
Kingcable銀IC PC
fullcity數位線
hclin
來自: Taipei City
文章windwalker 發表於 週六 10月 08, 2005 12:02 am
耗子 寫:儘管如此…依照「暈倒」系統的慣例
安裝過程中會自動移除..... :Q
也會問你要不要backup舊版的driver..... :p
windwalker
來自: 偽裝成台北人的高雄人
文章jefm 發表於 週六 10月 08, 2005 12:56 am
Before you install:
自爆...
剛剛裝PatchMix弄了老半天總是裝到一半就應用程式錯誤...
結果手動先移除舊版PatchMix後就順利灌完了... :mad:
jefm
來自: 屏東
文章耗子 發表於 週六 10月 08, 2005 1:04 am
jefm 寫:自爆...
well... it's really nothing...
偉大的 M$ 暈倒系統總是有辦法叫人暈倒
所以對它來說最好的辦法通常就是最笨的辦法 :aa:
耗子
來自: 耗子窩
文章andyaries 發表於 週三 10月 12, 2005 11:16 pm
弟已下載
但還未用
感謝樓主丫~~~
要GMAIL的PM你的mail給我
andyaries
來自: 台南
文章andyaries 發表於 週四 10月 13, 2005 10:08 am
windwalker 寫:
hclin 寫:我灌反了
難怪有錯誤訊息
灌反應該是沒差才對啊....
沒錯
偶用的還是官網下載的05/01/03的defult session咧...
這樣也會error... :aa: :aa:
要GMAIL的PM你的mail給我
andyaries
來自: 台南
文章obicome 發表於 週六 10月 15, 2005 11:31 am
holygod 寫:
修復這兩項缺失就是萬幸了!!..呵呵.. :ale:
obicome
註冊時間: 週二 9月 14, 2004 11:54 am
文章pcvhaha 發表於 週日 10月 16, 2005 3:34 pm
請問一下 我抓了1.81版的兩個檔
EmuPMX_PCApp_L6_1_81_06.exe 16.6mb
EmuPMX_PCDrv_L6_1_81_05.exe 24.3mb
執行了卻跑出解檔案動作 然後就沒動作了 ?
我是windows 2000
pcvhaha
文章: 21
文章karuito 發表於 週日 10月 16, 2005 6:24 pm
Minimum System Requirements:
Windows XP SP2 or Windows 2000 SP4
如果還不行,卸載舊版本驅動再安裝
最後由 karuito 於 週四 10月 20, 2005 6:51 pm 編輯,總共編輯了 1 次。
karuito
註冊時間: 週六 7月 10, 2004 7:25 pm
文章J@ck 發表於 週二 10月 18, 2005 2:24 am
改變好像真的不小, 剛開始不太確定, 昨天從頭重灌了一次 driver, 真的很容易聽出來. (Analog out)
感覺比之前厚實一點, 我覺得聲音比較討喜, 值得一試.
J@ck
文章: 17
註冊時間: 週日 3月 28, 2004 2:27 pm
文章Terencecool 發表於 週二 10月 18, 2005 4:59 am
收到收到 有空來試試看
這兩天小弟終於明白怎樣使0404和我的A2value共存了
搞了有點給他久 :mad:
然後一開始也有點搞不清楚控制台切換的方式 :ale:
不知道EMU什麼時候會釋出可傳送DTS/DD/AC3數位訊號的驅動 :roll:
Terencecool
註冊時間: 週二 9月 13, 2005 10:25 am
來自: NCTU CM
正在瀏覽這個版面的使用者:Majestic-12 [Bot] 和 34 位訪客
