nettyu 寫:現在煩惱的是電源
我是想把體積盡量縮到最小
電源這部分真的要好好的規劃才可以
infinitesymphony 寫:Okay, I'll elaborate.
0404 USB has:
-better DAC (AKM AK4396 vs. Burr-Brown PCM2702)
-better ADC (AKM AK5385A vs. none)
-more input choices (1/4" TS, XLR, coaxial S/PDIF, optical TOSlink, USB vs. USB)
-more output choices (1/4" TS, 1/4" TRS, 1/8" TRS vs. one output of your choice)
-higher bit depth and sampling rates (24-bit/192 kHz max vs. 16-bit/48 kHz max)
-better SNR (117 dB vs. 105 dB)
-separate headphone output
-monitor preamp control
-cleaner external power
Alien DAC has:
-variable parts choice
In other words, practically everything
n4k33n 寫:The Alien has a couple distinct advantages:
Its small. Very small in fact. You could take it with you on a trip with no problems. It can be powered by just usb, without an external power supply. It won't take up half your desk like an 0404. Its cheaper. And the alien dac does sound good. It was a starter dac for me and I'm glad I went with it and a better amp instead of picking a halfway point like the 0404 where if you wanted to upgrade later you would need to spend more money. Seriously, if I were you, I would get an alien and that mini3. Or even an M3 or PPA or Gilmore Lite, and no dac. It won't sound quite as good as the 0404 right off the starting line. Its better to dump your money into a good amp to start with and work out from there.
steel 寫:為了這個小東西還從DIGIKEY購買,是有點過份
5% 比較好找
componentbeggar 寫:其實SMD電阻有一個很有趣的優點__疊疊樂,找不到阻值的,就用疊的,一個PAD三、四個電阻疊起來不是難事!
componentbeggar 寫:這輩子第一節電子學課,老師問了兩個問題:
1. 電子&電機的最大差異在哪?
2. 讀工的&讀商的最大差異在哪?
第2題答案是【誤差】
銀行職員三點半後,帳差NT.1,就要抓帳!
誤差零才能work的電路,保証被修理到不行!
600ohm標準電阻裏根本沒這個值!
componentbeggar 寫:我的音響DIY部落格
http://tw.myblog.yahoo.com/componentbeggar
阿榮 寫:那我就繼續備料了~~ 謝謝~~
steel 寫:Ferrite 600R. 1206 package
這個有在賣嗎?
正在瀏覽這個版面的使用者:Google [Bot] 和 241 位訪客
