AIO到貨通知
版主: 侯姐
AIO到貨通知
文章侯姐 發表於 週四 4月 16, 2009 7:13 pm
2009年最受矚目的電腦訊源產品--RME AIO終於在今天晚上抵達音悅,首批到貨量不多,有興趣的朋友請加緊腳步。
AIO規格:
PCI-e版
The new 38-channel 192 kHz Multiformat card
1 x Stereo Analog I/O (192 kHz)
1 x ADAT I/O (up to 192 kHz via S/MUX4)
1 x SPDIF I/O (192 kHz)
1 x AES/EBU I/O (192 kHz)
1 x MIDI I/O
1 x Phones Output (separate DAC, 192 kHz)
TotalMix
Differences to HDSP 9632
PCI Express interface
S/PDIF and AES/EBU simultaneously operational
even lower latencies
independent phones out with additional DAC
direct support of HDSP TCO
Tech Specs
1-Lane PCI Express Endpoint device (no PCI Express to PCI Bridge), revision 1.1.
2.5 Gbps line speed
Packet-based full-duplex communication (up to 500 MB/s transfer rate)
Supported sample frequencies: Internally 32, 44.1, 48, 64, 88.2, 96, 176.4, 192 kHz. Externally 28 kHz - 200 kHz
8 buffer sizes/latencies available: 0.7 ms, 1.5 ms, 3 ms, 6 ms, 12 ms, 23 ms, 46 ms, 93 ms
All settings changeable in real-time
Automatic and intelligent master/slave clock control
Enhanced Mixed mode: All inputs and outputs simultaneously operational
TMS (Track Marker Support): Supports CD/DAT start-IDs and the read out of CD subcode
Unique status windows for record and playback, showing mode and sample rate
DIGICheck, RMEs unique metering and analysing tool
Digital inputs and outputs ground-free transformer coupled
3-stage hardware level control for analog inputs and outputs
Servo-balanced analog input and output, DC-coupled signal path
192 kHz / 24-bit converters. SNR 112 dB RMS unweighted, 115 dBA
Maximum input and output level (0 dBFS @ HiGain): +19 dBu
Low impedance headphone output (75 ohm), separate DAC and playback device
Super low jitter design: < 1 ns in all clock modes
音悅侯姐
侯姐
文章: 1585
註冊時間: 週三 4月 04, 2001 6:10 pm
來自: 音悅音響
回到 音悅音響產品服務版
正在瀏覽這個版面的使用者:Bing [Bot] 和 46 位訪客
