Fostex TH-X00 Purpleheart 8/26 官方回覆
發表於 : 週六 8月 17, 2013 1:20 am
<<<< 2016 / 8 / 26 更新 >>>>>>>>
Hi there,
Thanks for contacting Massdrop Support! We are sorry that your headphones arrived in that condition and we would be happy to assist you!
Based on new information that has become available, we have reason to believe that our remaining inventory might also be affected with some of the QC issues (specifically, the bubble wrap markings). Because of this, we are currently holding off on shipping replacement units until after we have completed a thorough inspection of the available units.
To resolve your issue, we can offer the following options:
You can wait until we are able to send replacements and exchange your unit for a new one. You will be able to keep your unit until you receive the replacement.
You can return your unit for a refund.
We can send replacement ear cups and you could swap them with the damaged ones. (Like option 1, this option would also depend on the status of our remaining inventory, so it might take a little while to sort.)
Please let me know how you would like to proceed. Also, are you able to provide me with the serial number of your unit? We are collecting serial numbers of affected units and sending the information to the manufacturer.
As for methods on how to clean it off, we do not have a suggestion at the moment as everything we have tried does not work.
Best,
如果一樣有遇到此問題&不想自行處理的大大,
就也發信過去跟官方回覆&登記囉
<<<< 2016 / 8 / 24 更新 >>>>>>>>
初run 4hr 聽感分享
視聽器材如下 :
PC > ATH SDP2000 > Luxman DA-200 > Luxman JPC10000 > Luxman P-1u
對照組 : 差不多價位 & CP 值 的 A900X-LTD
為了避免器材差異&及時切換比較,
所以直上P-1u的雙耳機孔
今日曲目
Macross Fダイアモンドクレバス (演唱會影片)
https://youtu.be/Tq_QFzbA5GU
其實本來想說要用一般版,
但是網路找不到該影片,
&發現其實這個版本也挺不錯
1080p HD + 雙歌姬 + 背景音只有鋼琴整個就是人聲大PK
1:35 ~ 2:00 這一小段
貴方に出逢い STAR輝いて アタシが生まれて
愛すればこそ iあればこそ
希望のない 奇跡を待って どうなるの?
涙に滲む 惑星の瞬きはgone…
TH-X00 PH
目前高音域的表現雖清晰,
聲音帶的光澤感不強烈,
且有微微木頭特性的共鳴感,
但仍有微微朦朧罩住的感覺,
邊緣仍帶點齒音?並沒有完全展開.
A900X-LTD
高音域清晰分明線條感非常強,
歌姬們在唱時聲音是順利滑過延伸向上飆高,
並帶著閃耀光芒的感覺,
但是因為金屬腔體特性,
較為理性不耐聽.
3:10 ~ 4:10 這一小段 (本曲高潮部分)
燃える様な流星 捕まえて 火を灯して
愛していたい 愛されてたい
冷えたカラダひとつで 世界は どうなるの?
張り続けてた 虚勢が溶けてくlong for…
どうしてなの? 涙溢れて 止められない
TH-X00 PH
在本段因為是整首曲目高潮部分,
除歌姬們唱時力度增加~音域提高,
多個部分可以明顯聽出顫音唱法,
但因上殼體特性,
部分邊緣霧化&殘響的感覺更加明顯,
且有時與鋼琴聲混雜再一起.
A900X-LTD
一樣是人聲清晰明亮~線條明顯,
與鋼琴完全分明不混雜,
在顫音部分真實還原,
聲音結束時馬上就收掉,
並不像X00會有極短暫的迴繞,
止められない這段飆上去時較為突兀,
跟前一句的尾音太過切斷導致有種中斷感.
&各位有遇到殘膠的大大....
不知有何建議解?
2016/08/23 Fostex TH-X00 Purpleheart 純開箱
這篇是沉寂已久的再次分享,
雄雄還找不到之前開的個人心得分享集中串XD
會買這隻主要是這木頭真的挺少見的,
加上AZ大鐵趴時,
配上小弟的DA-200聲音頗合胃口,
算是打算拿來與A900X-LTD交互使用的替用機.
目前因為在公司所以無法試聲音,
所以只能先簡單的開箱照分享,
回家試過聲音後再更新.
外觀簡單總結就是幾乎跟桃花心木板一樣,
間隙問題依舊存在,
小弟拿到的還多贈送溢膠,
只能說為了便宜這點細節就被偷掉了.
(怕消火請一張張點開)
外箱
Open
去袋
總內容物
編號 : 0008 (個位數超爽www)
木殼
以下消火圖
防消火分隔線wwwwwwww
1. 轉軸殘膠
2. 轉軸殘膠
3. 木殼與塑膠框體間隙
Hi there,
Best,
就也發信過去跟官方回覆&登記囉
初run 4hr 聽感分享
視聽器材如下 :
為了避免器材差異&及時切換比較,
所以直上P-1u的雙耳機孔
今日曲目
其實本來想說要用一般版,
但是網路找不到該影片,
&發現其實這個版本也挺不錯
1:35 ~ 2:00 這一小段
愛すればこそ iあればこそ
希望のない 奇跡を待って どうなるの?
涙に滲む 惑星の瞬きはgone…
TH-X00 PH
目前高音域的表現雖清晰,
聲音帶的光澤感不強烈,
且有微微木頭特性的共鳴感,
但仍有微微朦朧罩住的感覺,
邊緣仍帶點齒音?並沒有完全展開.
A900X-LTD
高音域清晰分明線條感非常強,
並帶著閃耀光芒的感覺,
但是因為金屬腔體特性,
較為理性不耐聽.
燃える様な流星 捕まえて 火を灯して
愛していたい 愛されてたい
どうしてなの? 涙溢れて 止められない
TH-X00 PH
在本段因為是整首曲目高潮部分,
除歌姬們唱時力度增加~音域提高,
多個部分可以明顯聽出顫音唱法,
但因上殼體特性,
部分邊緣霧化&殘響的感覺更加明顯,
且有時與鋼琴聲混雜再一起.
A900X-LTD
一樣是人聲清晰明亮~線條明顯,
與鋼琴完全分明不混雜,
在顫音部分真實還原,
聲音結束時馬上就收掉,
並不像X00會有極短暫的迴繞,
止められない這段飆上去時較為突兀,
跟前一句的尾音太過切斷導致有種中斷感.
&各位有遇到殘膠的大大....
不知有何建議解?
這篇是沉寂已久的再次分享,
會買這隻主要是這木頭真的挺少見的,
加上AZ大鐵趴時,
配上小弟的DA-200聲音頗合胃口,
目前因為在公司所以無法試聲音,
所以只能先簡單的開箱照分享,
回家試過聲音後再更新.
外觀簡單總結就是幾乎跟桃花心木板一樣,
間隙問題依舊存在,
小弟拿到的還多贈送溢膠,
只能說為了便宜這點細節就被偷掉了.
(怕消火請一張張點開)
外箱
Open
去袋
總內容物
木殼
以下消火圖
防消火分隔線wwwwwwww
1. 轉軸殘膠
2. 轉軸殘膠
3. 木殼與塑膠框體間隙
