索尼大法 WM1發表
索尼大法 WM1發表
文章Skysoldier 發表於 週四 9月 01, 2016 8:12 pm
HEAD-FI介紹
MDR-Z1R is priced at around €2200
NW-WM1Z is priced at around €3300
NW-WM1A is priced at around €1200
TA-ZH1ES is priced at around €2000
MDR-1000X is priced at £330
The Signature Series headphones and Walkman®’s will be available in store from October 2016. With the amplifier joining them from end of November
Model Name NW-WM1Z
Available colours : Gold
Internal memory : 256GB
External memory : microSD
Display size/ Resolution : 4.0 inch、TFT colour LCD、FWVGA(854×480)
Compatible formats Music:MP3/WMA)/FLAC/LINEAR PCM / AAC / HE-ACC / APPLE LOSSLESS / AIFF / DSD
Sound Settings Direct Source, 10band equaliser / tone control, DSEE HX, DC Phase Linearizer, Dynamic Normaliser
Battery life Approx. 30 hours (FLAC 24bit/96kHz)
Bluetooth Bluetooth® v 4.2 Profile: A2DP/AVRCP/OPP Codec: LDAC/SBC
NFC : Yes
Other functions Display Lyrics, Sense Me TM Channels
Dimension (projecting parts not included) 65.3 x 123 x 19.9 mm
Weight : 455g
Included Accessories : Walkman NW-WM1Z, USB cable, leather case, wrist strap, startup guide, instruction manual
Model Name NW-WM1A
NFC : Yes
Dimension (projecting parts not included) 53.8 x 119.5 x 14.8 mm
Weight : 267g
Included Accessories : Walkman NW-WM1Z, USB cable, wrist strap, startup guide, instruction manual
Model name MDR-Z1R
Type Closed, dynamic (circum-aural)
Driver unit 70 mm, dome type (CCAW Voice Coil)
Sensitivity 100 dB/mW
Frequency response 4 Hz ~ 120,000 Hz
Impedance 64 Ω at 1 kHz
Power handling capacity 2,500 mW (IEC*)
Plug Gold-plated stereo mini plug for headphone cable, L-shaped gold plated balanced standard plug for balanced headphone cable
Weight(exclude cable) Approx. 385 g without cable
Supplied accessories Gold plated unimatch plug adapter (stereo 3.5mm to stereo 6.3mm) Headphone cable (approx. 3 m (118 1/8 in)), balanced connection headphone cable (approx.. 1.2m (47 1/4 in)) Hard case
Model name MDR-1000X
Type Dynamic, closed
Driver unit 40mm, dome type(CCAW Voice Coil)
Sensitivity 103 dB/mW (when the power is on)98 dB/mW (when the power is off)
Frequency response 4 Hz ~ 40,000 Hz
Impedance 46 Ω at 1 kHz (when the power is on)
16 Ω at 1 kHz (when the power is off)
Battery DC3.7V : Built-in lithium-ion rechargeable battery
Charging time Approx. 4 Hours
Usage hours Continuous music playback time : Max. 20 hours(NC ON), Max. 22 hours(NC OFF) continuous communication time : Max. 24 hours(NC ON), Max. 26 hours(NC OFF) Waiting Time : Max. 34 hours(NC ON), Max. 120 hours(NC OFF)
Weight(exclude cable) Approx. 275g
Headphone cable Approx. 1.5m, silver-coated OFC strands, gold-plated stereo mini plug
Headphone cable plug Gold-plated L-shaped stereo mini plug
Supplied accessories Micro USB cable (approx. 50cm) Plug adaptor for in-flight use Headphone cable (approx. 1.5m)
Carrying case
Model Name TA-ZH1ES
Description Headphone Amplifier
Colour Black
Dimensions (wxhxd) 210 x 65 x 314 mm
Weight 4.4 kg
Connectivity Coaxial input, optical input, Line L/R input, Pre Out (fixed / variable) Walkman / Xperia port (front-side), USB B (rear)
Format compatibility DSD native up to 22.4MHz, DSD DoP up to 11.2MHz, PCM up to 32bit / 768 kHz - USB B, DSD native up to 11.2MHz, DSD DoP up to 5.6MHz, PCM up to 32bit / 384kHz - Walkman / Xperia port
Headphone output Balanced standard (4.4mm in diameter), 3 pole mini (balanced connection, 3.5mm in diameter) x 2, XLR (balanced 4 pin), Standard (6.3mm in diameter), Stereo mini (3.5mm in diameter)
Sound Settings DSD remastering, DSEE HX, DC Phase Linearizer,
Accessories Remote control, remote batteries, AC power cord, digital cable for Walkman, USB cable
To buy or not to buy, that is the question.
MDR EX1000
MDR SA5000
SENNHEISER HD595
ATH EW9
ATH ES5
MDR ZX300
Skysoldier
文章: 67
註冊時間: 週三 9月 25, 2013 9:05 pm
來自: M78 星雲
Re: 索尼大法 WM1發表
文章z350philip 發表於 週四 9月 01, 2016 8:16 pm
https://www.cool3c.com/article/110738
比較在意 MDR-Z1R 和 TA-ZH1ES
不過都是2199美金簡直讓我跪了....
原本想說 Z1R應該是1000美金等級的差不多.....
希望之後會有相對應的大概 800~1000美元的開放式次旗艦
2200美金實在是 太人難以下手了
最後由 z350philip 於 週四 9月 01, 2016 8:29 pm 編輯,總共編輯了 1 次。
現在擁有的耳機:MDR-MA900, MDR-Z1000, MDR-SA3000, MDR-Z7, ATH-A900XLTD
曾經擁有耳機:AKG-K540,MDR-1R
訊源:CREATIVE SB-X-Fi音效卡, ATH-HA22TUBE,SONY PHA-2,SONY PHA-3
隨身訊源:XperiaZ2, PSV
電腦播放軟體:foobar2000+wasapi
未來目標:W1000Z,MDR-Z1R, TA-ZH1ES or TEAC UD503
z350philip
文章: 68
註冊時間: 週三 2月 13, 2013 7:40 pm
Re: 索尼大法 WM1發表
文章KowdanL 發表於 週四 9月 01, 2016 8:19 pm
另一邊看到WM1Z是3199美元,這邊變3300歐元,反正價格都是高到嚇人就是 :mad:
$ONY敢推這種價格的話就看端出來的是什麼了,所以說那個MDR-R20呢(誤
耳罩式耳機:STAX SR-007A / SR-507 / Philips Fidelio X2 / ATH W1000 / A900XLTD
擴大機:KGSShv Carbon /w QED Reference Qundoit / STAX SRM-727A
DAC:Luxman DA-200 /w Luxman JPA-15000
壁插:CARADS 4181US
耳道式耳機:Westone W4R + 管迷QER-SE2
隨身訊源:Pioneer XDP-300R
KowdanL
文章: 85
註冊時間: 週六 10月 27, 2012 12:49 am
Re: 索尼大法 WM1發表
文章evo2001 發表於 週四 9月 01, 2016 8:33 pm
看到這金額也真的是跪了,雖然多少還是會期待表現
只是...2199美實在有點嚇人啊
evo2001
註冊時間: 週五 3月 23, 2007 2:19 pm
Re: 索尼大法 WM1發表
文章YouXiang 發表於 週四 9月 01, 2016 8:48 pm
2200歐!?
眼神死......
果然傳說中接棒R10....
人生啊,果然如同那香醇的西湖龍井,哪怕你身價一萬一千八,也註定最終要被浸泡在杯具之中...(?
YouXiang
註冊時間: 週五 5月 06, 2016 6:17 am
來自: 中華民國 新北市
Re: 索尼大法 WM1發表
文章Skysoldier 發表於 週四 9月 01, 2016 9:13 pm
z350philip 寫:https://www.cool3c.com/article/110738
2200美金實在是 太人難以下手了
加拿大官網已經上架了
羊皮耳墊
無氧銅鍍銀耳機線
平衡線
硬盒
手工MIJ :bs: :bs:
看來這次是下重本了
外面那層感覺像是跟SA5000類似
耳墊應該類似z7只是改羊皮
框架應該也類似z7
開始存錢了
MDR EX1000
MDR SA5000
SENNHEISER HD595
ATH EW9
ATH ES5
MDR ZX300
Skysoldier
文章: 67
來自: M78 星雲
Re: 索尼大法 WM1發表
文章Skysoldier 發表於 週四 9月 01, 2016 9:17 pm
平衡線竟然是5pin 4.4mm的新規格
然後頻響直逼010的120kHz
期待視聽報告
MDR EX1000
MDR SA5000
SENNHEISER HD595
ATH EW9
ATH ES5
MDR ZX300
Skysoldier
文章: 67
來自: M78 星雲
Re: 索尼大法 WM1發表
文章gameguy 發表於 週五 9月 02, 2016 11:44 am
$ony發功,我窮人看了看還是以聲論價吧。 :poorcry:
台灣要聽到試聽機還要等一陣子了(明年前不知道有沒有希望) :mad:
繼續創造傳奇的耳機,看頭像就知道是哪一支耳機了 :)
gameguy
文章: 820
註冊時間: 週六 5月 10, 2003 10:44 pm
Re: 索尼大法 WM1發表
文章玄霄‧永劫 發表於 週五 9月 02, 2016 1:15 pm
gameguy 寫:$ony發功,我窮人看了看還是以聲論價吧。 :poorcry:
聽說11月上市,12月能否試聽到,就看sony是否有誠意開放展場聽 :)
玄霄‧永劫
文章: 446
註冊時間: 週三 7月 23, 2008 12:44 am
來自: 高解析音質的音響世界
Re: 索尼大法 WM1發表
文章zhang230631 發表於 週五 9月 02, 2016 7:42 pm
NW-WM1Z 竟然超過 10 萬台幣,完全是索尼的技術宣示產品,恐怕是 Astell&Kern 霸佔高端市場而推行的對應策略。
MDR-Z1R 令我相當期待,採用高剛性的鎂合金振膜負責中高頻,外圍鍍鋁液晶振膜負責低頻,如此結構應用在耳機上倒是少見 ,能否超越 MDR-R10 這副傳奇動圈呢?剛好我聽過 MDR-R10,等待 MDR-Z1R 上市後再來試試。
TA-ZH1ES 既然是冠上 ES 後綴,那麼技術、規格、用料、設計肯定不會遜色,可以當作前級也是一項賣點,D.A. 混合擴大電路的運作方式令我好奇,因為全數為擴大技術已經不需要轉換成類比訊號,直接由 PWM 脈衝調變即可輸出,但 S-Master 劣勢在於輸出功率不高,猜想是兼顧類比擴大電路的高驅動能力,而突發奇想採用的混合設計了。
文章: 4056
Re: 索尼大法 WM1發表
文章z350philip 發表於 週五 9月 02, 2016 11:48 pm
另外在SONY HK也看到別的新產品??!!
PHA-2A 還有 XBA-N3AP 等 1A則是多一個限量版??
https://www.sony.com.hk/zh/electronics/headphones/t/headphone-amplifiers
https://www.sony.com.hk/zh/electronics/headphones/t/in-ear-headphones
https://www.sony.com.hk/zh/electronics/headphones/t/headband-headphones
另外老實說Z1R的價格浮動頗大....
有2200歐 2200美 但讓我比較訝異的是 2399 AUD(澳洲幣)
以現在澳幣匯率24左右來算合台幣約57600元算是目前看到最便宜的價格...
http://www.sony.com.au/electronics/headband-headphones/mdr-z1r
隨身訊源:XperiaZ2, PSV
z350philip
文章: 68
Re: 索尼大法 WM1發表
文章zhang230631 發表於 週一 9月 05, 2016 12:50 pm
z350philip 寫:另外在SONY HK也看到別的新產品??!!
另外老實說Z1R的價格浮動頗大....
MDR-1A (Limited Edition)正是所謂的限量版,頭帶和耳墊都是透氣材質,顏色改為全黑而已 ; 至於 MDR-Z1R 的價格嘛,等待香港地區訂定後,台灣應該會賣得貴些。
文章: 4056
Re: 索尼大法 WM1發表
文章kanamelody 發表於 週三 9月 07, 2016 9:18 pm
不過看了一下規格
MDR-1A LTD(簡稱)
的阻抗似乎比較高 48歐姆
一般版本是24歐姆
我想多少會有一點聲音差別吧 0.0
耳機:SR225e,HD700,DT1770 PRO,DT990 CHROME,T1,DT880 CHROME, Amiron home, M1ST, DT700PROX , XBA-A3,IER-M9,AKG N40
DAC : TEAC UD-503 & ADI-2 DAC FS & D90SE , DAP : NW-ZX100,WM1A
擴: TERZO XX V2 → HA-501 & Dynalo MKII
二聲道 : 8300A → Aria 906
kanamelody
文章: 34
註冊時間: 週日 8月 16, 2015 11:02 am
Re: 索尼大法 WM1發表
文章z350philip 發表於 週四 9月 08, 2016 2:11 pm
日本SONY售價出爐 199880¥+稅 台幣約62000多一點些
http://www.sony.jp/headphone/products/MDR-Z1R/
E-イヤホン 價格215870¥ 台幣約67000左右
http://www.e-earphone.jp/shop/shopdetail.html?brandcode=000000103023&search=%A5%BD%A5%CB%A1%BC&sort=price_desc
希望台灣能定價在69900以內 不然就得找門路買水貨了
TA-ZH1ES 日本賣比較貴 250000¥ +稅
http://www.sony.jp/audio/products/TA-ZH1ES/
隨身訊源:XperiaZ2, PSV
z350philip
文章: 68
Re: 索尼大法 WM1發表
文章JoKouBe 發表於 週五 9月 16, 2016 11:01 pm
對MDR-Z1R有興趣的可以參考一下對岸評論
http://tinyurl.com/hhry86v MDR-Z1R 評論
http://tinyurl.com/zcrxegk MDR-Z1R 對 SE-Master1
希望不要讓大家失望了~~
JoKouBe
註冊時間: 週一 6月 12, 2006 9:00 pm
來自: 台南
Re: 索尼大法 WM1發表
文章玄霄‧永劫 發表於 週五 9月 16, 2016 11:24 pm
JoKouBe 寫:對MDR-Z1R有興趣的可以參考一下對岸評論
希望不要讓大家失望了~~
這還關乎前端搭配的問題,現在耳機潛能越來越高,評價常常都被評的很差(感覺大多是前端的等級跟不上耳機),當參考就好 ;)
玄霄‧永劫
文章: 446
來自: 高解析音質的音響世界
Re: 索尼大法 WM1發表
文章z350philip 發表於 週六 9月 17, 2016 8:07 pm
我是覺得新產品才剛出來熱機都不夠久吧?
至少要RUN200小時(甚至要更久)再下好壞的論定也不遲
就等著開賣時再說吧,預計年底才會買,那時候測評應該也會比較多
隨身訊源:XperiaZ2, PSV
z350philip
文章: 68
Re: 索尼大法 WM1發表
文章JoKouBe 發表於 週一 10月 03, 2016 11:29 pm
MDR-Z1R 台灣售價 55900元
比國外便宜啊~~~
JoKouBe
來自: 台南
Re: 索尼大法 WM1發表
文章z350philip 發表於 週二 10月 04, 2016 9:19 pm
TA-ZH1ES 倒是剛好在我預期的價格
69900
整組69900+55900=125800...
不曉得有沒有整組優惠價
隨身訊源:XperiaZ2, PSV
z350philip
文章: 68
Re: 索尼大法 WM1發表
文章z350philip 發表於 週五 10月 14, 2016 10:22 pm
MDR-Z1R似乎今天上市?!
有哪位大大有聽感或開箱了嗎 :D
隨身訊源:XperiaZ2, PSV
z350philip
文章: 68
正在瀏覽這個版面的使用者:沒有註冊會員 和 144 位訪客
