steel 寫::clap:
neogersang
要變成耳擴專家了...
highfly 寫:neo兄~
您那隻不是拜耳新旗艦DT990 2005 edition嗎?
怎麼是dt990 pro?
neogersang 寫:highfly 寫:neo兄~
怎麼是dt990 pro?
金拍謝...小弟問個很天才的問題
DT990 2005 edition <> dt990 pro?
highfly 寫:neogersang 寫:highfly 寫:neo兄~
怎麼是dt990 pro?
金拍謝...小弟問個很天才的問題
不同隻啦~~
新版這支新旗艦是銀色的~
PRO版是那隻黑塑膠殼的~
nettyu 寫:我還以為neo大怎麼會對DT990 Pro有興趣了哩
tom2517 寫:It's not a good idea to use ipod with amp because the signal coming out of the ipod is already amped by ipod. All you are doing is amplfying an amped sound.
Find a connector that uses the line out of the ipod.
neogersang 寫:tom2517 寫:It's not a good idea to use ipod with amp because the signal coming out of the ipod is already amped by ipod. All you are doing is amplfying an amped sound.
在某討論區看到(抱歉,小弟忘了)...將iPod的數位音量轉到最大...
等於不經過放大線路..
tom2517 寫:neogersang 寫:tom2517 寫:It's not a good idea to use ipod with amp because the signal coming out of the ipod is already amped by ipod. All you are doing is amplfying an amped sound.
等於不經過放大線路..
Where did you hear that?
Tom
neogersang 寫:在某討論區看到(抱歉,小弟忘了).
記得的話,我會附上連結..真是抱歉
但說實話,小弟還沒認真比較過,linout頭跟數位音量轉到底的效果
到底有沒差
neogersang 寫:tom2517 寫:neogersang 寫:tom2517 寫:It's not a good idea to use ipod with amp because the signal coming out of the ipod is already amped by ipod. All you are doing is amplfying an amped sound.
等於不經過放大線路..
Tom
在某討論區看到(抱歉,小弟忘了).
記得的話,我會附上連結..真是抱歉
到底有沒差
正在瀏覽這個版面的使用者:Bing [Bot], ultima1002 和 126 位訪客
