[新品情報]Etymotic出了支援Blue Tooth的Ety8
文章全是狼 發表於 週一 11月 20, 2006 11:15 pm
前幾天看到的...
圖檔圖檔
Another First
Wireless High Definition Noise-Isolating In-the-Ear
Etymotic Research developed the world's first in-ear high fidelity, noise-isolating earphones. Now enjoy the freedom of wireless in-ear earphones and audio quality expected from Etymotic.
iPod System Includes:
* ety8™ earphones
* 8•Mate™ adapter for iPod
* Leather case
* Eartips
* USB charging cable
* Filter changing tool and filters
System for other Bluetooth-enabled Devices Includes:
* ety8™ earphones
* Leather case
* Eartips
System Requirements
iPod (see iPod Models Supported). Compatible with devices supporting Bluetooth specification 1.1 and higher. Supporting A2DP and AVRCP profiles for stereo listening. USB power port for charging.
finding a way...
全是狼
註冊時間: 週日 1月 01, 2006 12:35 pm
來自: NCYU-BME
文章oScARSr 發表於 週二 11月 21, 2006 2:56 am
好重的感覺...
不過如果聲音和ER4有的拼的話,應該會大賣吧。
Portable : shure se215
oScARSr
文章: 22
註冊時間: 週五 9月 19, 2003 6:57 pm
來自: 中部
文章brushguy 發表於 週二 11月 21, 2006 9:45 am
的確看起來很重
應該不適合久戴唄
[隨身] 訊源:iaudio U3 → 耳擴:SM3v3(5534) → 耳機:E500PTH, Senn IE8, ER4P
[音響] DAC:Hifidiy mini usb dac → 按普:Dared MP5 → 喇叭:JohnBlue 3
brushguy
註冊時間: 週四 5月 25, 2006 2:33 pm
來自: 火星,HsinChu
文章robin7 發表於 週二 11月 21, 2006 9:47 am
感覺好『沈重』
走路不會掉下來嗎?
我想我不敢帶出門.......... :(
robin7
註冊時間: 週日 4月 30, 2006 11:43 am
文章全是狼 發表於 週二 11月 21, 2006 9:59 am
我回家就不上啦
所以現在貼給你們
相關參數
Technical Specifications
Transducer Type: Balanced armature
Frequency Response Accuracy: 50 Hz -6 kHz ± 3 dB; 20 Hz -15 kHz ± 6 dB
Noise Isolation: 35 dB with flanged eartip, deeply inserted
40 dB with foam eartip, deeply inserted
Max Output: 110 dB SPL
Weight: < 14 gms each earphone
Battery Life (iPod): 6-9 hours depending on the iPod model
Battery Life (non iPod): 7 to 10 hours depending on the connected BT device
Charging Time: 1 hour to 80% charge. 2-3 hours from empty battery to full charge
Range: >10 meters in free space
Body absorption: The body blocks transmission.
Use the music player on the same side of the body as the R earphone.
Volume Control Range (iPod): 50 dB
Volume Control Range (non-iPod): 40 dB
Total Harmonic Distortion: < 4% at 1 kHz at a nominal output of 100 dB SPL
Sampling Rate: 44.1 kHz, 16 bit resolution
Antenna: Internal
finding a way...
全是狼
來自: NCYU-BME
文章耗子 發表於 週二 11月 21, 2006 12:37 pm
全是狼 寫: Body absorption: The body blocks transmission.
其餘恕刪…
我笑了… :ale:
耗子
註冊時間: 週四 5月 19, 2005 2:43 pm
來自: 耗子窩
文章gradors2 發表於 週四 11月 23, 2006 12:10 am
希望聲音有一定水準
不論是外觀還是便利性
都讓我非常心動
(當然還有牌子)
列為年度必敗商品
-不過
台灣會進嘛?
gradors2
文章: 59
註冊時間: 週三 12月 03, 2003 5:55 pm
來自: 蠢蛋集散中心
文章疾風殘月 發表於 週四 11月 23, 2006 10:10 pm
感覺搖搖欲墜的說...
對了~耗子大,角錐是什麼
未成年請勿菸酒~也不能購買
狂飲狂抽等於慢性自殺,狂買避開賤糠姦,但仍要小心追殺
四千年前有酒蹤
騷人豪客甕裡蟲
褒貶參半無定譽
藉故加稅理難同
所以恁爸最討厭道貌岸然的小人!
疾風殘月
註冊時間: 週一 2月 20, 2006 9:42 pm
來自: CLUB AA (AKG & ATH)
文章ileedan 發表於 週四 11月 23, 2006 10:36 pm
好像耳掛式手機
訊源:CEC TL-51XR + Lavry Blue
擴大機:Unison–Simply two
喇叭:Concertino Home、Bose M3
線材:狐狸旗艦線(←最邪惡的毒物)
墊材角錐:黑金石、紫檀木、木內旗艦角錐(←最美妙的深淵)
ileedan
註冊時間: 週二 3月 28, 2006 11:10 pm
文章ACF 發表於 週五 11月 24, 2006 8:52 am
剛剛在逛網路看到價格了耶
"Ety.8 預計於下個月上市,單買耳機的話,需美金199元(約台幣6500元),iPod 套件則要美金299元(約台幣9800元),兩者皆附皮套組、替換用的耳塞及濾波器。"
:mad: 這IPOD套件的價格還真是精美...
耳機小嫩嫩 目前變成魅族M3+mini3+fi.5 PRO
ACF
註冊時間: 週二 11月 14, 2006 10:17 am
來自: TEA DIE YEE班本部<囧>
文章dmwc 發表於 週五 11月 24, 2006 9:35 am
不過依照經驗,BT 耳機音質都不太有水準,尤其這隻好像只有到 BT 1.1 ,自然音質鐵定沒水準
就是那個光,就是那個光,就是那個荷包花個精光
dmwc
註冊時間: 週日 12月 07, 2003 9:43 am
文章gradors2 發表於 週三 11月 29, 2006 12:29 pm
ACF 寫:剛剛在逛網路看到價格了耶
便宜到爆, 一定要買 :D
不過希望音質不會如各位網友所言這麼慘烈
但是我想這麼新的產品應該沒啥可參考的試聽報告吧.
莫非又要去當砲灰!?
對BT的產品很不熟
這玩意是怎樣? 有發射台嘛? 可接傳統3.5嘛?
gradors2
文章: 59
來自: 蠢蛋集散中心
文章dmwc 發表於 週三 11月 29, 2006 12:57 pm
gradors2 寫:對BT的產品很不熟
如果電腦要用BT耳機,要先買dongle,插入dongle後驅動會多一塊音效卡,然後把音效設定輸出到那音效卡上面,dongle會負責壓縮後傳輸到耳機,dongle 可以買2.0+EDR class1 (100m)的,不過這耳機只有BT1.1 class2 (10m),目前也沒看過class1的耳機
另外還有賣3.5轉BT,比dongle貴很多,沒聽過音質,不過因該不用測試了,BT音質就是那樣,聽過就知道等級到哪裡,和訊源好壞我個人覺得是沒差
dmwc
文章spark 發表於 週三 12月 06, 2006 4:36 pm
最近有朋友享用藍芽耳機聽音樂
有啥較好選擇嗎?
這隻他覺得太醜
  :ale:
spark
文章: 13
註冊時間: 週二 9月 30, 2003 11:55 am
正在瀏覽這個版面的使用者:boomga, Jerrywaw 和 215 位訪客
