Ath-SJ5 first impression
文章Kaotic 發表於 週一 12月 18, 2006 4:21 am
Ath-Sj5, after 12hr run-in 初聽的心得, sorry type in chinese is too much work for me, but here is..
click thumbnails to see the full size.
Only 12 hr burn-in so far.
ATH-SJ5
- Aesthetics, Build, & Comfort
The SJ5 is definitely a looker with its stylish design. The outer part of the earcups use hard plastic surface. It's a nice, simplistic headband design that also looks good on the head. Easily worn in public, I don't think anyone would laugh at it. I am much prefer this style over K81DJ style.
There's "lock-step" mechanism to adjust the fit of the headband. Unlike K26P in which the headbands use a click-free slider design that allows you to "pull" them down as you put the headphone on.
Materials are a combination of hard plastic and aluminum that will allow it to survive easy beatings. The headband is the sturdiest part on it with the arms not as much, but they're fairly inflexible on their own. Even with that, the arms still feel like you could break them off if you tried, as they have a hinge-y feel to them.
The earpads are made of pleather and provide a nice fit onto the ear. The earcups are larger than normal for a portable headphone, and will, for most standard ear sizes, be fully supra-aural. Not much pressure will be exerted on the ear, unlike K26p which exert great amount of pressure is all along the rim of the ear, which it could explain why K26p's isolation might be much better.
Due to the larger-than-normal earcups/earpads, since I have only experienced K26p, SJ5 is so much comfortable to wear. Can be worn easily for hours at a time without needing to take them off. Aside from the issue that pleather sticks, of course.
- Sound Quality
overall, Bass and Mids are the strongest point of SJ5
Bass is solid and not overly exaggerated or booming. moreover, bass is tight and controlled, It bangs, bops, and booms just like any subwoofer would, only without nearly as much power & authority of course.
Mids are very clear and detailed, just like usual A-T signature and very close to the Ck7. It's very easy-to-listen, pleasant presentation.
There's definately either treble roll-off or recess highs, to me, all the high-pitch instruments seems have turn down a few notches on the volume, but remain very detailed and clearity.
The impedance is rated at 32 ohms and indeed it's easy to drive. It can easily be directly driven from any DAP or PCDP without the need for an amp.
- Portability
The SJ5 folds up, and folds flat like grado. making it very convenient to transport. It does not come with a carrying case.
overall, I like it, and I prefer this over K81Dj.
Kaotic
註冊時間: 週三 11月 15, 2006 3:48 pm
文章全是狼 發表於 週一 12月 18, 2006 10:06 am
Great...!!! :clap:
下次有空小弟來翻譯一下.... :ya:
(到時翻不好還請大大指正阿... :ale: )
finding a way...
全是狼
註冊時間: 週日 1月 01, 2006 12:35 pm
來自: NCYU-BME
文章steveck 發表於 週一 12月 18, 2006 11:29 am
:o 就我聽過的小耳罩裡面 K81DJ算是很不錯了
SJ5的價格看起來應該是還要再便宜 應該是k26p的標準
不過k26p跟k81DJ卻差很多... :x
K81DJ音色也比K26p強橫很多就是了 不是每個人都喜歡這種音色
如果用2k以下買到這樣的水準倒是很超值呢
可以跟k81DJ比較一下嗎 多謝 :bs:
steveck
註冊時間: 週二 9月 20, 2005 10:10 am
文章cookie 發表於 週一 12月 18, 2006 11:37 am
全是狼 寫:Great...!!! :clap:
順便讓你練練英文
好去考試
:D
乳搖知腰力 日久變人妻
  我的Blog請點此 \/
cookie
註冊時間: 週二 1月 03, 2006 11:18 pm
來自: 電鍋大學
文章Kaotic 發表於 週一 12月 18, 2006 1:40 pm
steveck 寫:可以跟k81DJ比較一下嗎 多謝 :bs:
我沒有 K81DJ, can't compare.
Kaotic
Re: Ath-SJ5 first impression
文章steveck 發表於 週一 12月 18, 2006 2:19 pm
Kaotic 寫:
這應該表示你至少有聽過K81DJ吧
是單純音色的偏好嗎
因為一直想找個比較舒適的在實驗室戴... 實驗室一待就是好幾個小時
而且隔音太好了 XD 聽音樂時別人講話都聽不太到
想找個便宜耐用的丟實驗室 K81DJ還是外出用就好
steveck
文章全是狼 發表於 週日 1月 07, 2007 7:31 pm
感謝所有大大拔刀相助 :bow:
中文翻譯 寫:ATH-SJ5...Run了12個小時後的試聽心得...(抱歉...打中文對我來說實在是太麻煩了...但是還是打出來了...)
如果要看完整的尺寸...請點選縮圖...
只有Run-in 12個小時...
ATH-SJ5
- 外型,結構&舒適度
由於SJ5有型的設計,他絕對是個亮眼的耳機.
外面的耳機殼使用的是硬質的塑膠.
頭帶極盡簡化的設計十分的不錯,戴在頭上也很好看.
在公共場合,你也可以毫不猶豫的帶上他,我想應該不會有人笑你.
總之...比起K81DJ,我比較喜歡這款的款式.
頭帶有卡榫可以調整.
不像K26P的頭帶,使用的是滑動式的設計,
帶上耳機...那將會使耳機被"拉"下來.
用料結合鋁和塑膠可以輕鬆的承受一些較輕微的(耳機單元的)震動
最堅固的地方是頭帶,肢臂則沒有像他那麼堅固,雖然肢臂並不大容易移動.
不過就算這樣,他仍會讓你覺得你一試他就會斷,僅管它有Y型活動關節.
耳罩則是用人造皮做的,帶起來很舒適.
以攜帶性的耳機來說,他的耳罩的大小算是比較大的.
對於一般的耳朵尺寸,它可以完全的覆蓋住,使用起來也比較不會有壓力,(這裡指的是夾的力量)
不像K26P,他施加極大的壓力在耳殼的邊緣,
或許...這可以解釋為什麼他的隔音比較好...
我只戴過K26P,但是我覺得SJ5更舒適,這都要歸功於他那大於一般(攜帶式)耳機的耳罩/外殼.
可以輕鬆的帶上好幾個小時而不用拿下來.
當然,前提是不介意他是人造皮.
- 音質
整體來說...低頻和中頻是SJ5的強項.
低頻非常的結實,不會過分的渲染/刺激
此外,低頻的控制力佳,就像低音喇叭一樣"蹦磅叫"(台語),就只在力道相差一點點了.
中頻十分的乾淨/清晰,就如往常的A-T設計(我實在是不知道這是啥)和Ck7十分的相近.
舒適的呈現音樂,可以輕鬆的聆聽.
所有高音的音量都好像被降低了, 或是高音有凹進處
以我的認知,所有高音壓的耳機似乎都好像要降低音量,但是仍要非常清晰和乾淨.
抗組是32歐姆,很容易驅動.
不需耳擴直上硬碟式隨身聽CD隨身聽仍然很好推.
- 便利性
SJ5是向上摺疊的,並且摺起來和Grado一樣的平.這使得他攜帶方便.
沒有附攜帶包.
總之....我蠻喜歡的,而且相較於K81DJ我更喜歡他.
今天突然想起K大的這篇...
花了一些時間...終於翻好了...
大家就先湊合湊合著看/順便幫我解決一些難翻的句子吧... :ale:
BTW
藍色的地方是我加的...並不是原文章的內容喔...
(這篇等等會加入索引... :ya: )
改錯字..... :ale:
最後由 全是狼 於 週六 1月 13, 2007 7:17 pm 編輯,總共編輯了 3 次。
finding a way...
全是狼
來自: NCYU-BME
文章wgundamcustom 發表於 週一 1月 08, 2007 10:57 am
:clap: :clap: :clap: :clap: :clap: :clap:
做的好...........
:cry: 感動呀~總而言之"摒磅叫"翻的最好(因為是台語有種親切感,雖然...我的台語不輪轉)
Beatings(是要翻"打擊"嗎...?)
應該是.....撞擊或衝擊吧 :ale:
wgundamcustom
文章: 325
註冊時間: 週四 7月 27, 2006 2:38 pm
來自: 已經消失的隨身版
文章全是狼 發表於 週一 1月 08, 2007 12:09 pm
wgundamcustom 寫::clap: :clap: :clap: :clap: :clap: :clap:
做的好...........
想了一下....
我覺得應該是要翻(耳機單元的)震動可能會比較好ㄟ...
BTW
昨天番的很盡興...
結果忘了寫英文作文.... :mad:
finding a way...
全是狼
來自: NCYU-BME
文章mmeegg 發表於 週一 1月 08, 2007 6:06 pm
我的翻譯是: 即使如此, 肢臂感覺還是會斷如果去試折, 尤其她是Y型的支架/肢臂... :ale:
mmeegg
註冊時間: 週四 1月 04, 2007 10:04 am
來自: 中壢
文章chiahaolu 發表於 週一 1月 08, 2007 7:50 pm
mmeegg 寫:Even with that, the arms still feel like you could break them off if you tried, as they have a hinge-y feel to them.
我覺得比較像是 即使如此 如果去試折 支臂感覺還是會斷 即使像是有Y型絞鏈的設計 (或者翻成關節 我知道hinge joint 算是一種關節的分類)
不知道這樣翻對不對
chiahaolu
註冊時間: 週一 11月 13, 2006 11:26 pm
文章全是狼 發表於 週二 1月 09, 2007 12:07 pm
哇勒~大家翻的都不一樣... :ale:
那只好有請這篇的原作者啦...
(K大~快出來吧..... :x )
finding a way...
全是狼
來自: NCYU-BME
文章Kaotic 發表於 週二 1月 09, 2007 1:55 pm
hehe, Ok..
Beating = 撞擊 或者是 衝擊 都可.
DAP = 就是像硬碟式隨身聽, 例如 Ipod, Iaudio X5L, 還有像 Ipod Nano, Iaudio U3, T2. 都是DAP.
either treble roll-off or recess highs (所有高音的音量都好像被降低了, 或是高音有凹進處).
It does not come with a carrying case. (不包括攜帶包)
Kaotic
文章全是狼 發表於 週二 1月 09, 2007 2:56 pm
Kaotic 寫:hehe, Ok..
感謝~明天來更新...
可是...
這句...樓上的C大和M大...翻的都不一樣ㄟ...
K大...只好有請你再來翻一下吧....辛苦了... :oops:
finding a way...
全是狼
來自: NCYU-BME
文章brushguy 發表於 週二 1月 09, 2007 3:46 pm
Kaotic 寫:Materials are a combination of hard plastic and aluminum that will allow it to survive easy beatings. The headband is the sturdiest part on it with the arms not as much, but they're fairly inflexible on their own. Even with that, the arms still feel like you could break them off if you tried, as they have a hinge-y feel to them.
材質是硬塑膠和鋁組合而成,所以可以耐一些小撞擊.頭帶部分是最牢固的,支臂雖沒這麼硬,但是仍相當牢靠.話雖如此,如果你稍微用力,感覺上支臂仍然滿容易斷的,僅管它有Y型活動關節.
(亂亂翻,加減看)
最後由 brushguy 於 週三 1月 10, 2007 9:49 pm 編輯,總共編輯了 1 次。
[隨身] 訊源:iaudio U3 → 耳擴:SM3v3(5534) → 耳機:E500PTH, Senn IE8, ER4P
[音響] DAC:Hifidiy mini usb dac → 按普:Dared MP5 → 喇叭:JohnBlue 3
brushguy
註冊時間: 週四 5月 25, 2006 2:33 pm
來自: 火星,HsinChu
文章全是狼 發表於 週三 1月 10, 2007 1:55 pm
:ale:
.....現在B大和C大翻的一樣...M大又跟他們不一樣....
K大只好再有請你了.... :x
finding a way...
全是狼
來自: NCYU-BME
文章Kaotic 發表於 週三 1月 10, 2007 2:46 pm
用B大的翻譯就可以了 :D
Kaotic
文章Bagheera 發表於 週三 1月 10, 2007 2:48 pm
狼哥翻的很不錯喲!^____^如果有問題下次小弟可以幫忙翻翻看!(只是,小弟雖然英文好,中文就爛啦!注音打起來還真慢。。。 :ale:
ATH-A9X,ATH-A900X, AKG K550, ATH-EM9d, ATH-EW9
Bagheera
註冊時間: 週一 11月 25, 2002 6:30 pm
文章全是狼 發表於 週三 1月 10, 2007 2:54 pm
感謝所有回覆的大大幫小弟翻句子阿....
等等下一節來更新一下...
(快上課了.... :aa: )
finding a way...
全是狼
來自: NCYU-BME
文章wgundamcustom 發表於 週三 1月 10, 2007 2:54 pm
Bagheera 寫:狼哥翻的很不錯喲!^____^如果有問題下次小弟可以幫忙翻翻看!(只是,小弟雖然英文好,中文就爛啦!注音打起來還真慢。。。 :ale:
這就有請大大勞心勞力啦
中文爛?
沒關係.......常來灌水就會打的很快
EXP. 我(以前不管打什麼文超慢的 :ale: )
wgundamcustom
文章: 325
來自: 已經消失的隨身版
文章Bagheera 發表於 週三 1月 10, 2007 3:03 pm
全是狼 寫:
我試試看喔∼
材質為堅硬的塑膠和鋁製,可以容耐 有限度的撞擊。頭帶是這支耳機最堅固的部份,但是肢臂沒有它那麼堅固,雖然肢臂並不大會搖擺(inflexible意思乃硬硬的,不會動的。),感覺上還是覺得如果你試著去扳它,肢臂會斷掉,因為它感覺有點像用鍊子栓著的那種觸感。
Bagheera
文章mmeegg 發表於 週三 1月 10, 2007 3:23 pm
不要叫我大啦~~ :ale:
我也覺得B大翻譯最正確.其實我想翻的意思, 與他們很相似.不知為何翻出來就是不一樣....請大家多多包含.
mmeegg
來自: 中壢
文章全是狼 發表於 週三 1月 10, 2007 3:48 pm
Bagheera 寫:
全是狼 寫:
我試試看喔∼
:mad: ....
我看成flexible.................. :ale:
finding a way...
全是狼
來自: NCYU-BME
文章brushguy 發表於 週三 1月 10, 2007 9:44 pm
[quote="全是狼] :mad: ....
我看成flexible.................. :ale:[/quote]
我也是..... :mad:
brushguy
來自: 火星,HsinChu
文章全是狼 發表於 週六 1月 13, 2007 7:21 pm
鞭一下文.... :ho:
文章翻譯更新完畢... :D
finding a way...
全是狼
來自: NCYU-BME
正在瀏覽這個版面的使用者:Google [Bot], MorrissLom 和 204 位訪客
