開一個XRCD區
音樂、古典音樂、電影等,各種形式的音樂軟體討論。
版主: devilhades
開一個XRCD區
文章basic 發表於 週二 3月 20, 2001 6:36 pm
JCP兄:
在FTP站裡可不可以開一個XRCD專區..
我們就可以把XRCD全部放在裡頭..
這一群可以算是CD錄音的極緻..
這樣應該比較方便吧..
謝謝您.. :)
basic
文章: 177
註冊時間: 週六 1月 06, 2001 7:45 pm
文章JCP 發表於 週二 3月 20, 2001 7:52 pm
可以啊,但是128k的我就不會放進去了,要壓最好的音質大家才會聽得爽。
JCP
文章: 1203
註冊時間: 週一 12月 04, 2000 9:28 pm
文章JCP 發表於 週二 3月 20, 2001 8:02 pm
有一位網友在我的網站上音樂討論區轉貼一篇文章,可以作為壓高音質mp3的參考。
-V0 -b160 -mj --athlower 5
It is important to NOT USE CRC CHECK! This wastes bits.
Options explained:
-V0 is the highest quality variable bit rate (VBR) encoding algorithm. In my extensive testing, VBR outperforms constant bit rate (CBR) encoding. VBR can dynamically adapt to more demanding music to provide a higher quality mp3 by encoding difficult frames with higher bitrates and encoding less difficult frames with lower bitrates. You can see VBR at work when you encode using
this method.
-b160 sets the MINIMUM bitrate.
-mj sets LAME to use variable stereo/joint stereo encoding. Depending upon the stereo sound field, LAME can intelligently decide what method will produce the best quality. At any given bitrate, -mj will encode with higher quality than -ms (fixed stereo) because it encodes the DIFFERENCE between
channels, thereby saving more bits to apply towards the information contained in each channel.
--athlower 5 increases the sensitivity of the encoding algorithm and increases the amount of data being compressed. The ATH is the perceptual encoding algorithm that decides what is important audible nformation and what is not.
JCP
文章: 1203
文章yatho 發表於 週三 3月 21, 2001 7:54 am
絕對同意!!!
yatho
文章: 22
註冊時間: 週日 3月 18, 2001 12:09 pm
回到 新音樂、影音討論版
正在瀏覽這個版面的使用者:沒有註冊會員 和 15 位訪客
