據說Graham Slee Voyager非常厲害!英國旅行者耳擴,我打算入一部試試···
文章maguoshuai 發表於 週四 12月 04, 2014 1:51 pm
這是能找到比較有權威的評價!
在HEAD-FI近期的一个资深发烧友所做的对17台主流随身耳放的大评比中,Voyager最终评价被评为第一!具体帖子在这里:http://www.head-fi.org/forums/f5/update-review-17-mainstream-portable-amps-lisaiii-added-icube-soon-237038/
参与评比的17种随身耳放如下(根据作者从最好到最差的排序):
1. Graham Slee Voyager
2. LaRocco PRII
3. Lisa III
3. Go Vibe Petite
4. XIN Reference
4. XIN SMIV
5. Hornet non-m (original)
5. Portaphile V2^2(maxxed)
6. Meier Corda Move
6. MisterX XP w/8397
7. iBasso D1 (amp only with rolled opamps)
8. Hornet M
8. SR71
9. Tomahawk
10. Porta Corda III
11. Go-Vibe V6
12. TTVJ Millet
技术参数
尺寸:L. 12.5 W. 6.7 H. 2.8 (cm)
重量:180 grams approx. (700 grams with plug top PSU)
电池寿命:50 hours continuous play, 2-3 weeks average usage
输出功率:12mW rms into 32 Ohms, 10mW rms into 600 Ohms
频响:Flat: 5Hz to 70kHz (-3dB), Contour: +10dB at 45Hz and 20kHz
声道平衡精度:0.5dB*
哼声和噪音:-94dB CCIR Q-pk 20Hz-20kHz, <-100dB "A" curve weighted
失真 (THD+底噪):at 80Hz: 0.03%, at 1kHz: 0.03%, at 5.6kHz: 0.05%, at 16kHz: 0.13%
电源: 9V电池 (MN1604; 6LR61), USB 5V via "mini-B" (internal analogue voltage conversion to 9VDC), AC/DC 稳压电源 12-24V DC, (带极性保护)
* = typical
大陸耳机俱乐部小白对Voyager耳放的观点:
这是一款声音纯正、细腻、通透的随身耳放,推力并不特别大,但声音的纯正感、细腻度和通透度,是随身耳放里罕见的。听过不少国产的随身耳放,力气很大,推力似乎很足,但声音粗糙、偏硬、不通透,品质上都无法和Voyager相比。
Voyager接iPod播放器或SONY D50、Hifiman HM801等带line out的播放器,都能取得良好的音质,比起原机直推,改善显著,特别是在通透感、细腻度、解析等方面,都会有明显的提升。
英国What Hi-Fi杂志对Voyager的评价:
For (优点) Great potential in applications; well balanced and detailed sound (使用上的潜力大; 平衡良好和细致的声音)
Against (缺点) We're not big on the tone switch (我们对音调控制不感兴趣)
Working off either mains or battery power, the Voyager is a solidly built, fairly slim plastic box, with a volume control knob, line in and headphone sockets, power source selector switch and tone contour switch. (Voyager可以用墙插供电或者电池供电,是一个制作精良,体形纤细的塑料盒子. 它具有音量钮,输入口,一个耳机插口,供电方式选择开关,以及音调开关.)
Graham Slee says the Voyager is ideal as an iPod accessory, but while it does improve the sound, it's hard to imagine using it on the move due to the unit's bulk and extra cabling involved. (厂家说Voyager是Ipod的理想配件. 当然,尽管它确实能改善音质,但很难想象在户外走动时带着它欣赏音乐的样子. 体积不小,还需要额外的接线.)
Where the Voyager really shines as a concept is as an accessory to items such as laptops and well, pretty much anything else with a headphone socket, although you'd need good quality headphones to get the best result. (Voyager真正的发光点是配合笔记本电脑使用,或者配合其他任何带有耳机输出的装置使用. 尽管你需要优质的耳机来取得最佳效果.)
Plugged in, you get a full-bodied, solid sound that's well balanced and packed with detail. The tone contour switch adds brashness to the top-end when on 'contour' and makes for a wearing listen. (你获得的是丰满的,结实的声音,平衡良好,细节出色. 打开音调开关,会给高频增加一种粗砺感,使人听着觉得疲劳.)
Music never sleep
maguoshuai
文章: 36
註冊時間: 週日 8月 10, 2014 2:44 pm
Re: 據說Graham Slee Voyager非常厲害!英國旅行者耳擴,我打算入一部試試···
文章123ORZ 發表於 週四 12月 04, 2014 4:46 pm
看看就好,還是自己聽過比較準.
之前我也有Voyager,不過我覺得直上訊源比較好聽~~~
徵 AKG K1000
123ORZ
文章: 52
註冊時間: 週日 3月 27, 2011 10:56 pm
文章maguoshuai 發表於 週四 12月 04, 2014 5:12 pm
123ORZ 寫:看看就好,還是自己聽過比較準.
看了内部结构,我觉得是来坑钱的货…打算入大陆的凯音C5吧…不折腾了…
Music never sleep
maguoshuai
文章: 36
文章Randius 發表於 週三 12月 10, 2014 8:38 am
maguoshuai 寫:在HEAD-FI近期的一个资深发烧友所做的对17台主流随身耳放的大评比中,Voyager最终评价被评为第一!具体帖子在这里:http://www.head-fi.org/forums/f5/update-review-17-mainstream-portable-amps-lisaiii-added-icube-soon-237038/
近期?那帖子的最後一則回復也已經是5年前的事了 :b14:
Randius
註冊時間: 週四 9月 30, 2010 6:50 pm
文章maguoshuai 發表於 週三 2月 11, 2015 3:55 pm
Randius 寫:
最终还是入了 大家嘴里 传唱比较靠谱的 黑鸟 sr71A 挺满意!之前入的红雀感觉性价比很好!
Music never sleep
maguoshuai
文章: 36
文章gameguy 發表於 週三 2月 11, 2015 5:03 pm
我台灣國 民旁邊路過的 :hard:
SR71A,怎麼不直接衝SR71B :mad:
Lisa III,之後就L3,台灣國 內有關L3聽感的資料幾乎沒看過,慘 淒淒慘慘戚戚
我台灣國 民旁邊路過的 :hard:
繼續創造傳奇的耳機,看頭像就知道是哪一支耳機了 :)
gameguy
文章: 820
註冊時間: 週六 5月 10, 2003 10:44 pm
文章maguoshuai 發表於 週三 2月 11, 2015 5:32 pm
gameguy 寫:
我台灣國 民旁邊路過的 :hard:
我台灣國 民旁邊路過的 :hard:
感觉放差不多就行 不如折腾音源了!到这水平就满意了,不折腾了!退烧···· :gogogo:
Music never sleep
maguoshuai
文章: 36
文章马尾控 發表於 週日 2月 15, 2015 4:09 pm
那个帖子实在太老了,很多放大器都是停产已久的,我也挑几个用过的说下自己感受。
SR71A是很不错的一台耳放,三档增益切换可以应对绝大部分耳机。声音中正大气,建议搭配ipower us电池,续航力能达到20多小时,声音也比较细腻。
SR71B以及后续的入侵者,则是平衡输出利器。
lisa3+LLP个人也很喜欢,声音富有活力,动态强悍,驱动pk1 er4之类的耳塞可谓随身耳放之冠,但体积实在太大了。
Meier Corda个人使用过他家的stepdance,高频很是犀利,空气感好,通透感强,体积也很小巧,奈何续航力一般。
cayin C5是大陆老牌胆机厂家斯巴克的产品,声音略带暖调,驱动力不俗,性价比很好。不过个人最欣赏的是他对低阻高敏耳塞的适应性,驱动K3003,parterre ie800 se846都非常棒,这一点是更高价位的sr71a所不能及的,不过如果您如果主要驱动这类耳塞,也可以选择他的升级版本,C5dac,15年三月份上市,可以用于安卓与ios设备解码,耳扩部分做了调整,声音是中性还原,细腻透明的风格,声场解析力等比C5更胜一筹。
马尾控
文章: 44
註冊時間: 週六 7月 24, 2010 11:01 am
文章Yazi 發表於 週一 2月 16, 2015 6:04 pm
马尾控 寫:那个帖子实在太老了,很多放大器都是停产已久的,我也挑几个用过的说下自己感受。
43
感謝樓主和马尾控大的分享 :oops:
不過近幾年耳機擴大器進步不少,並且不少播放器本身就具有非常好的驅動能力
相較於額外加個隨身耳擴,小弟個人比較推薦選一個驅動能力足夠的播放器
或是直接購買不是需要耳擴即能有好表現的耳機 ;)
現在小弟都把這些耳擴當做調音工具而已 :haha:
耳機:Ultimate Ears In-Ear Reference Monitors、SONY MDR-Z7 & Audio-Technica AD2000X
部落格:http://yazilightar.pixnet.net/blog
Yazi
文章: 644
註冊時間: 週一 5月 30, 2011 6:53 pm
正在瀏覽這個版面的使用者:Bing [Bot] 和 154 位訪客
