Emu的新driver....patch
文章herroyuihk 發表於 週三 6月 15, 2005 5:40 pm
E-MU?0404, 1212M, 1820, 1820M Digital Audio System, Emulator?X and Proteus?X Driver patch V1.8......
Feature Enhancements:
?Improved ASIO / WDM recording performance during bursts in PCI bus activity, in order to eliminate recording dropouts
?Improved ASIO driver behavior when used with Sonar
?ASIO driver now fully recovers after an ASIO application crashes or is abnormally terminated
?Improves PCI performance by automatically setting optimal PCI Latency values for the DAS hardware
?Improved efficiency of PCI bus utilization, to allow for better recording performance on systems with other PCI-intensive devices (such as Effect Accelerators, SATA hard disk drives).
Fixes:
?Fixed bug where Cubase SX would not accept sample rate changes from PatchMix DSP
?Fixed bug where Sonar would crash when using ASIO at a sample rate that was not the same as PatchMix DSP
?Fixed a bug introduced in driver V1.71 affecting 1212m, 1820 and 1820m , where symptoms may incude AudioDock not responding correctly and External Clock not functioning.
好像沒有和音質相關的事項......
忘了說要去creative才有.....emu還沒有....
最後由 herroyuihk 於 週三 6月 15, 2005 7:44 pm 編輯,總共編輯了 1 次。
herroyuihk
註冊時間: 週六 4月 24, 2004 11:05 pm
文章oScARSr 發表於 週三 6月 15, 2005 7:19 pm
感謝,
看起來加強了不少相容性的問題,
ASIO在打電動的時候會破音和靜音的問題不知道有無改善。
官網好像還沒有放上。
Portable : shure se215
oScARSr
註冊時間: 週五 9月 19, 2003 6:57 pm
文章rexyang 發表於 週三 6月 15, 2005 8:07 pm
真ㄉ出ㄌ耶
這網站不賴 提供給大家
http://www.productionforums.com/emu/top ... IC_ID=3643
[size=12a7656]Input 1 :Luxman D321--Motou XLR
Input 2 :E-mu0404--Motou Power Cable and kingcable RCA
Amp : CEC HD51--Motou Power Cable
Headphone : HD580---HD650 cable
Speaker : Klipsch-ProMedia GMX A2.1--Kingcable RCA ,Motou speaker and Power Cable[/sizea7656]
rexyang
註冊時間: 週一 2月 07, 2005 2:51 pm
來自: 屏東
文章SCH 發表於 週四 6月 16, 2005 2:14 pm
E-MU的官網今天也把新Driver放上去囉,
把連結po上來給大家參考
1212m:
http://www.emu.com/support/files/downlo ... Platform=1
0404m:
官網有特別說明,請更新v1.80驅動時也要同時更新PatchMix DSP Application patch 1.71a.
提供給各位E-MU愛好者版友參考注意喔. :bs:
No Pain. No Gain.
SCH
註冊時間: 週一 4月 12, 2004 10:57 am
文章oScARSr 發表於 週四 6月 16, 2005 6:26 pm
感謝分享,
檔案名稱和creative的不太一樣。
oScARSr
文章darwinnis 發表於 週四 6月 16, 2005 8:09 pm
多謝提供來源 我也更新完畢 不過沒啥感覺哪裡有變..
darwinnis
註冊時間: 週六 12月 11, 2004 4:06 pm
來自: TAIPEI
正在瀏覽這個版面的使用者:Bing [Bot], seanshow 和 28 位訪客
