最近很想搞搞發燒耳機線
文章阿毛 發表於 週三 1月 16, 2002 1:04 am
我有看到耳機頭有3.5MM 1/4' 0.173'三種可是我不知道像HD590用的耳機頭是多大的
好像是0.173的
只好想辦法找個樣品來試試看吧:)
音響跟劇場,都是一種虛擬性的真實:P
阿毛
文章: 4248
註冊時間: 週二 12月 05, 2000 2:44 am
文章阿毛 發表於 週二 2月 05, 2002 1:38 am
CARDAS跟Stefan AudioArt 都出了耳机線-for HD600/HD580
在今年的LES VEGAS的CES中發表
2/4/2002: Cardas Cables showed a replacement cable for the Sennheiser HD600 headphones at the CES 2002. Very little information is available at this time. Cardas has scheduled this product for release in early March. It will come in a standard length of 1.5m and retail for about $150.
2/4/2002: Stefan AudioArt has released its Equinox and Vision 1 replacement cables for the Sennheiser HD580/HD600 headphones. The cables are constructed similarly to other cables in their respective series (see previous announcements for details). A 9-foot length of the Equinox retails for $189 or $159 for the Vision 1.
看來
這東西的市場應該不小
要不這些廠商怎麼會跳進來
還是趕快試試看Tara Lab吧:)
cardas的照片與說明
<img src="http://www.shows.soundstagelive.com/shows/ces2002/jan10c/cardas_headphone.jpg" border=0>
Roger Kanno wears a pair of Sennheiser HD-600 headphones that are equipped with the new Cardas $150 replacement cord. Besides Cardas cabling, the cord features a proprietary headphone plug that is said to eliminate crosstalk problems inherent in the standard plug's design.
其它有趣的東西
這是Monarchy的老闆吧
他是華人喔
<img src="http://www.shows.soundstagelive.com/shows/ces2002/jan08/monarchy_poon.jpg" border=0>
Monarchy's C.C. Poon displays his DIP Upsampler ($299), which can upsample a digital signal up to 24 bits and 96kHz. It can also output a 48kHz signal, so you can use it along with non-24/96 DACs and still get upsampling benefits.
Silverline Audio 也是
<img src="http://www.shows.soundstagelive.com/shows/ces2002/jan08/silverline_yun.jpg" border=0>
Alan Yun of Silverline Audio poses with his diminutive SR11 speaker ($1499/pair) in briarwood finish.
Zingali 這個喇叭真的很漂亮
<img src="http://www.shows.soundstagelive.com/shows/ces2002/jan07/zingali_littlespeaker.jpg" border=0>
Billed as the world's smallest horn-loaded speakers, the Zingali Satellite costs $799/pair with a passive subwoofer. The speakers are $400/pair alone.
Bel Canto出DAC2了
<img src="http://www.shows.soundstagelive.com/shows/ces2002/jan10b/belcanto_dac2.jpg" border=0>
Bel Canto's popular DAC1 has been replaced by the DAC2 ($1500), which uses the same case and upsamples to 24 bits/192kHz. The upgrade from DAC1 to DAC2 will cost $500-$600.
音響跟劇場,都是一種虛擬性的真實:P
由 阿毛 於 02/28/2002 18:02:05 修改
阿毛
文章: 4248
文章RogerShih 發表於 週二 2月 05, 2002 1:40 am
看到DAC就眼睛發亮, 可是1500美金太貴了, 買不起 :(
全世界的個人網站版工中,最遜、最窮的一個就素偶 :eeh:
文章tony 發表於 週二 2月 05, 2002 2:19 am
How should I care for the cable?
As for the cable, when you are finished using your headphones, please correct any twist in the cord before storing it away. This will prevent the cord from retaining any kinks. Especially because the cord cover is made of 100% silk, it is easier for the cord to retain unwanted twists or kinks. Please correct such issues promptly and before storing your headphones.
對不起JY大:b14:
這裡是說由於是絲做
所以要特別小心
要不然就很易打結........
tony
文章: 209
註冊時間: 週一 12月 10, 2001 4:52 am
文章nomo 發表於 週二 2月 05, 2002 5:51 am
阿毛!我們就靠你啦!
只想舒服的聽音樂!
NOMO.............
nomo
文章: 407
註冊時間: 週一 4月 09, 2001 11:41 pm
來自: 中華民國,台北縣,
文章cinglong 發表於 週二 2月 05, 2002 10:10 am
有阿<我以前就有一些李茲線外面還有一層蠶絲披覆
純絲?
真是第一次聽到線材披覆用這個:eeh:
音響跟劇場,都是一種虛擬性的真實:P
cinglong
文章: 588
文章阿毛 發表於 週二 2月 05, 2002 5:09 pm
他弟弟DAC-1我有看到特價美金899左右吧
害我猶豫半天
:eeh:
音響跟劇場,都是一種虛擬性的真實:P
阿毛
文章: 4248
文章阿毛 發表於 週四 2月 28, 2002 6:09 pm
搞發燒耳機線的關鍵就在那組小小的耳機pin
<img src="http://isweb34.infoseek.co.jp/computer/bbsitake/images2/hd600_connector_s.jpg" border=0>
很不幸
找不到成品
問過訂做的事情
開模就要20萬左右
現在又請人去問cadas賣不賣
這大概是最後的希望了:b14:
音響跟劇場,都是一種虛擬性的真實:P
阿毛
文章: 4248
文章arvo 發表於 週日 3月 03, 2002 11:13 am
恩....Stefan AudioArt 又推出了一款新的 HD600/580 耳機線...
比 Equinox 便宜 $40 USD = $149 USD........有興趣的人去看看:
http://www.stefanaudioart.com/SpectrumB ... eries.html
:grin:
arvo
文章: 49
註冊時間: 週一 2月 25, 2002 1:39 am
來自: TAIWAN
正在瀏覽這個版面的使用者:sempame 和 131 位訪客
