主要是2000年以前的,還有解碼晶片
ACOUSTIC RESEARCH CD-07 SAA7220
ACCUPHASE DP85 AD1853 NJM4580
ACCUPHASE DP90 PCM63
ADC CD 250XR PCM54
AKAI CD25/26/27/32/36 KSS210A
AKAI CD37 PCM67P KSS210A NJM4558
AKAI CD52 KSS210A
AKAI CD55 AD1856 KSS210A
AKAI CD57 PCM67PJ KSS210 CXD1167Q
AKAI CD62 BO38258J
AKAI CD650/70 KSS210A
AKAI CD69 PCM63 KSS210A
AKAI CD-A70 MB84053B KSS123A//BO367214J
AKAI CD-M839 PCM56
AKAI CD79 KSS210A
AKAI CD750 KSS210A
AKAI CD73/93 PCM56 KSS155A(884806401)
ALBA CD420 PCM54
ALCHEMIST NEXUS APD32A 2x TDA1549
AMC CD60 PCM1716
AMC CD8A MN6474 (Technics MASH)
ANTHEM CD1 PCM1702
ARCAM ALPHA 5 TDA1541 CDM9
ARCAM ALPHA 5 PLUS TDA7310 SAA7220P/B TDA1541A CDM9
ARCAM ALPHA 6 SM5864
ARCAM ALPHA 7 PCM1710
ARCAM ALPHA 7SE PCM1716
ARCAM ALPHA 8 SM5864AP
ARCAM ALPHA 9 dCS RingDAC
ARCAM CD72 PCM1716
ARCAM CD92 dCS RingDAC
ARCAM DELTA 70.2 TDA1541-S1 cdm4/31
ARCAM DELTA 70.3 LM627
ARCAM DELTA 270 PCM69
ARCAM DELTA BOX 5 PCM67
ARYE CX-7 PCM1738
ARYE D-1 PCM1704
AUDIO ALCHEMY ENGINE v3.0 AD1862
AUDIO ANALOGUE MAESTRO AD1855
AUDIO INNOVATIONS ALTO PCM1716
AUDIO NOTE CD-1 PCM1710
AUDIO NOTE CD-2 AD1865
AUDIO NOTE DAC-3 PCM63
AUDIO RESEARCH CD1 SAA7341
AUDIOLAB 8000 CD CS4329
AVI SC2000MC PCM63
BLAUPUNKT CP2650 PCM54
CAMBRIDGE AUDIO CD1 TDA1541
CAMBRIDGE AUDIO CD2 SAA7210 SAA7220P/A 4xTDA1541 CDM2
CAMBRIDGE AUDIO CD3 TDA1541A
CAMBRIDGE AUDIO CD4SE CS4327
CAMBRIDGE AUDIO CD6 TDA1305T
CAMBRIDGE AUDIO D500 CS4327
CARVER SD/A 450 MN6474
C.E.C. 530CD2 Y3015
C.E.C. 680CD LC7881
CONDOR CD950 YM3020
COPLAND CDA277 PCM63
COPLAND CDA288 PCM63-K
CROWN CD2111R LC7881
CYRUS CD7 PCM1716
CYRUS dAD1 TDA1311
CYRUS dAD3 TDA1305
CYRUS dAD3Q AD1861
CYRUS dAD7 AD1861
DENON DA-500 PCM1702
DENON DCD-315 NKS240A
DENON DCD-435 PCM1716E
DENON DCD-480 PCM61 NKS240A
DENON DCD-485 PCM1735
DENON DCD-500 PCM54 KSS123A
DENON DCD-520 KSS210A
DENON DCD-580 PCM67P NKS240A
DENON DCD-590 PCM61
DENON DCD-600 KSS152A
DENON DCD-610/20 KSS210A
DENON DCD-615/25 NKS240A
DENON DCD-635 PCM61P
DENON DCD-650F PCM1700P
DENON DCD-655 PCM1702
DENON DCD-660 KSS210A
DENON DCD-680 PCM69A
DENON DCD-685 PCM1702
DENON DCD-690 PCM61
DENON DCD-695 PCM61
DENON DCD-700 PCM54HP KSS123A
DENON DCD-715 NKS240A
DENON DCD-725 PCM61P-L
DENON DCD-735 PCM61
DENON DCD-755AR PCM1702
DENON DCD-800 PCM54 KSS152A
DENON DCD-810 KSS210A
DENON DCD-820 PCM56 KSS210A
DENON DCD-825 NKS240A
DENON DCD-860 KSS210A
DENON DCD-890 PCM61P NKS240A
DENON DCD-895 NKS240A
DENON DCD-900 KSS123A
DENON DCD-910 KSS210A
DENON DCD-920 PCM61 KSS210A
DENON DCD-980 PCM61P NKS240A
DENON DCD-1015 PCM61P NKS240A
DENON DCD-1000 KSS123A
DENON DCD-1100 PCM53JP-V KSS123A
DENON DCD-1290 NKS240A
DENON DCD-1300 KSS123A
DENON DCD-1400 PCM56
DENON DCD-1420 PCM54HP KSS210A
DENON DCD-1450AR PCM1702
DENON DCD-1500 PCM54HP-K KSS123A
DENON DCD-1500mk2 PCM56 KSS151A
DENON DCD-1520 PCM64 KSS151A
DENON DCD-1530 PCM61
DENON DCD-1550R PCM61
DENON DCD-1550AR PCM61P
DENON DCD-1560 PCM1701
DENON DCD-1650R PCM1702
DENON DCD-1700 KSS123A
DENON DCD-1800 PCM53
DENON DCD-2060G/80G NKS240A
DENON DCD-2560 4x AD1862
DENON DCD-2700 PCM1702J
DENON DCD-S10/3000 PCM1702J
DENON DCD-3300 PCM56P-K KSS123A
DENON DCD-3520 PCM64 KSS151A
DENON DCD-3560 PCM58P-K
DENON DCD-S1 PCM1702
DENON DCM-280 PCM1748
DENON RCD-100 PCM1710
DENON UCD-F10 PCM61
DENON DN-2000F NKS240A
DIORA CD-502 TDA1543
DUAL CD130 CX20017
DUAL CD20 PCM53
EXPOSURE CD TDA1545A
EZO FOG STAGE3 AD1853
FISCHER AD935 LC7881 SFP1
FISCHER Z1 PCM58 SFP1
GRUNDIG CD103 LC7881
GRUNDIG CD9000 TDA1541A CDM4.11(£95.00)
HARMAN KARDON HD200 YM3020
HARMAN KARDON HD500 PCM53
HARMAN KARDON HD710 MN6474
HARMAN KARDON HD720 PCM1710
HARMAN KARDON HD730 SAA7350
HARMAN KARDON HD760 PCM1702
HARMAN KARDON HD7225 MN6474
HARMAN KARDON HD7300 PCM61
HARMAN KARDON HD7325 MN6474
HARMAN KARDON HD7400/7500 KSS210A
HARMAN KARDON HD7525 PCM61P
HELIOS MODEL1S CS4328 (36 bit, ETNA)
HELIOS MODEL2S CS4328 (36 bit, ETNA)
HELIOS MODEL3S CS4328 (36 bit, ETNA)
HELIOS STARGATE CS4328 (36 bit, ETNA)
HEYBROOK SIGNATURE PCM67
HIGH TECH GOLDLINE CX904 YM3020
JVC XL V22 PCM54 OPTIMA2
JVC XL V221 LC7881 OPTIMA5
JVC XL V250BK PCM56 OPTIMA2
JVC XL V311BK MN6471 OPTIMA4S
JVC XL V464 MN35500 OPTIMA6S
JVC XL V1100 PCM54 OPTIMA1
KENWOOD DP47 TD6720N KSS152A
KENWOOD DP87 KSS152A
KENWOOD DP460 TD6709N
KENWOOD DP660SG KSS152A
KENWOOD DP730 KSS210A
KENWOOD DP850 CX20152
KENWOOD DP920/30/50 KSS210A
KENWOOD DP1030 KSS210A
KENWOOD DP1050 NKS240A
KENWOOD DP1060 RCTRH8136
KENWOOD DP1080 LC78620E
KENWOOD DP1100D CX20152
KENWOOD DP1510 PCM56 KSS210A
KENWOOD DP2000 CX20152
KENWOOD DP2010 PCM56P KSS210A
KENWOOD DP2030 KSS210A
KENWOOD DP2050 NKS240A
KENWOOD DP2060 RCTRH8136
KENWOOD DP2080 LC78620E (LC78820)
KENWOOD DP3010/30/50 KSS210A
KENWOOD DP3060 NKS240A
KENWOOD DP3080 SM5864
KENWOOD DP4030 KSS210A
KENWOOD DP4090 KAN03
KENWOOD DP5010/30/40 KSS210A
KENWOOD DP5020 PCM1701P KSS210A
KENWOOD DP5090 MN35502 JVC
KENWOOD DP7002 PCM1702
KENWOOD DP7030 CXD2552 KSS210A
KENWOOD DP7040/50 KSS210A
KENWOOD DP7060 TDA1547
KENWOOD DP7090 8x PCM1702
KENWOOD DP8020 KSS152A
KOREA CHINA CD 022 KDA0316LN
KOREA HCD 630 Y3015
KRELL KAV280 PCM1704
LINN GENKI PCM1723
LUXMAN D 102 TD6709N
LUXMAN D 103 PCM1701
LUXMAN D 112 1x PCM56
LUXMAN D2 92 LC7881
MARANTZ CD7 TDA1541AS2 (double crown)
MARANTZ CD10 SAA7310 TDA1547 CDM4/D36
MARANTZ CD11LE/II TDA1547 CDM4/D36 HDAM
MARANTZ CD1010/20 CDM12.1
MARANTZ CD14 TDA1547 CDM12.1
MARANTZ CD15 TDA1547 CDM4-MD
MARANTZ CD16D SAA7310 TDA1547 HDAM
MARANTZ CD17mkII TDA1370 TDA1547(DAC7) VAM1201 NJM2114/HDAM
MARANTZ CD19 SM5872
MARANTZ CD23 CDM9
MARANTZ CD273 CDM2
MARANTZ CD38 TDA1545 CDM12.1
MARANTZ CD385 CDM4
MARANTZ CD40 SAA7310 SAA7220 TDA1541/A CDM4/19
MARANTZ CD42 SAA7310 SAA7350 ? CDM4//691.30209
MARANTZ CD42 II CDM4
MARANTZ CD43 SM5872BS CDM12.1/05 NJM4560
MARANTZ CD45 TDA1540 CDM2/29
MARANTZ CD46 CDM12.1
MARANTZ CD48 TDA1545//1549 CDM12.1
MARANTZ CD50 TDA1541 CDM4/19
MARANTZ CD52 SAA7310 SAA7321GP CDM4
MARANTZ CD52SE SAA7310 SAA7350(Bitstream) CDM4 NE5532
MARANTZ CD53 SM5872BS CDM12.1 NJM2114
MARANTZ CD56 TDA1541 CDM4/25
MARANTZ CD57/57 II CDM12.1
MARANTZ CD583/93 CDM4/19
MARANTZ CD60 TDA1541 A CDM4/19 NE5534
MARANTZ CD63 SM5872BS CDM12.1 HDAM
MARANTZ CD63II SM5872 CDM12.1
MARANTZ CD63mkII KI SM5872 CDM12.1
MARANTZ CD63SE SM5872BS CDM12.1
MARANTZ CD65 SAA7310 TDA1541 CDM4/25
MARANTZ CD65 II SAA7210 SAA7220B TDA1541 A CDM4/19
MARANTZ CD67 SM5872 CDM12.1
MARANTZ CD67SE SM5872 CDM12.1
MARANTZ CD67II OSE SM5872 CDM12.1
MARANTZ CD72 SAA7310 SAA7350(Bitstream) CDM4/19
MARANTZ CD72mkII SE SAA7310 TDA1547 CDM 4/28//CDM4/19 HDAM
MARANTZ CD73 SAA7000/10 SAA7020 2xTDA1540 CDM1
MARANTZ CD74 SAA7000/10 SAA7020 2xTDA1540 CDM1
MARANTZ CD75 CDM4/25
MARANTZ CD75NB CDM2-160
MARANTZ CD75XNB 691.20464
MARANTZ CD80 TDA1541 CDM1/mkII(CDM4.19) single opamps
MARANTZ CD84 TDA1540 CDM1
MARANTZ CD85 CDM1/mkII
MARANTZ CD94/mkII TDA1541 CDM1
MARANTZ CD873 CDM2-0500//CDM4/11
MARANTZ CD883 CDM4/19
MARANTZ CD4000 SAA7378 TDA1545 VAM1201 NJM4560
MARANTZ CD5000 SAA7378 TDA1549 VAM1201 NJM4560
MARANTZ CD6000 SAA7378 SM5872 VAM1201 NJM2114
MARANTZ CD6000KI SAA7372 SM5872BS VAM1201 HDAM
MARANTZ CD6000OSE SAA7372 2xSM5872 VAM1201 HDAM
MARANTZ SA-12S1/SA14 CS4397 HDAM
MARK LEVINSON N'36 PCM1702 (vagy PCM1704)
MARK LEVINSON No. 390S AD1853
MERIDIAN 508 CS4329
MICROMEGA LEADER SAA7321GP
MICROMEGA LOGIC SAA7321
MICROMEGA PREMIUM18 new CS4327
MICROMEGA STAGE2 SAA7321GP
MICROMEGA STAGE6 TDA1305
MISSION dAC5 TDA1547
MISSION dAD3 TDA1305
MISSION PCM4000 TDA1541
MITSUBISHI DP109 PCM56
MITSUBISHI MC5100 PCM56
MUSICAL FIDELITY x-ray PCM1716 NE5532
MUSICAL FIDELITY Tri-Vista PCM1738 NE5532
MUSICAL FIDELITY A2 YDC103
MUSICAL FIDELITY DIGILOG TDA1541
MUSICAL FIDELITY E60 YDC103
MUSICAL FIDELITY E624 PCM1716
MYRYAD T-10 CS4327
MYRYAD T-20 CS4327
MYRYAD MC100 CXD2565
NAD 502 MN6474AM KSS210A
NAD 510 SAA7350 CDM12.1
NAD 515 CDM12.1
NAD 512 MN6474 KSS210A
NAD 522 PCM1710
NAD 5100 PCM56
NAD 5325 LC7881
NAD 5425 MN6471M
NAD C520 PCM1710
NAD S500 CS4390
NAIM AUDIO CD1 TDA1541
NAIM AUDIO CD2 TDA1541
NAIM AUDIO CD3 TDA1541
NAIM AUDIO CD3.5 TDA1305
NAIM AUDIO CD5 TDA1305
NAIM AUDIO CDI TDA1541AS1 (single crown)
NAIM AUDIO CDS11 PCM1702K
NAKAMICHI CD PLAYER 1 PCM1700P
NAKAMICHI CD PLAYER 4 AD1864N
NAKAMICHI MB 4 LC78840
NAKAMICHI MB 5 LC78840
NAKAMICHI CDP 2E TDA1541A
NAKAMICHI OMS 1E PCM56
NAKAMICHI OMS 4E PCM54
NAKAMICHI OMS 5E TDA1540
NAKAMICHI OMS 7E PCM54
NEC CD610 PCM54
ONKYO DX-704 MN6472 (Technics MASH)
ONKYO DX-6430 YM3020
ONKYO DX-6470 PCM56
ONKYO DX-6550 Integra TC9219 (ONKYO 8D-3170-1)
ONKYO DX-6570 PCM58
ONKYO DX-6620 LC7881
ONKYO DX-7011 TC9237
ONKYO DX-7211 SM5874
ONKYO DX-7500 ONKYO 8S-3380-1
ONKYO DX-7711 Integra SM5864AP
ONKYO DX-7911 Integra SM5864AP
ORELLE CD100 TDA1541
PARASOUND CD M839 PCM56
PARASOUND C/DP1000 PCM67
PHILIPS AK601/630/640/729/CCD310/320 CDM4/19
PHILIPS CD-80 TDA1541
PHILIPS CD-85M TDA1541
PHILIPS CD-94M TDA1541
PHILIPS CD-100 TDA1540 CDM0
PHILIPS CD-101 TDA1540 CDM1
PHILIPS CD-104 TDA1540 CDM0/CDM1
PHILIPS CD-115/130/140 CDM4/19
PHILIPS CD-150/1 CDM2/29
PHILIPS CD-160 CDM4/25
PHILIPS CD-162/4 CDM4/19
PHILIPS CD-163 CDM12.1/05
PHILIPS CD-200 TDA1540 CDM0
PHILIPS CD-202 TDA1540 CDM0
PHILIPS CD-204 TDA1540 CDM0
PHILIPS CD-210 TDA1543 CDM4/19
PHILIPS CD-210 CDM4/19
PHILIPS CD-300/303 SAA7210 SAA7020 2xTDA1540 CDM1
PHILIPS CD-304 TDA1540 CDM1
PHILIPS CD-304 MkII (alu chassis) SAA7210 SAA7220P/A TDA1541 CDM1
PHILIPS CD-310 CDM4/19
PHILIPS CD-340 CDM4/19
PHILIPS CD-350 TDA1541 CDM2/29
PHILIPS CD-360 CDM2 //CDM4/25
PHILIPS CD-371/3 CDM4/11
PHILIPS CD-380 TDA1543/1/1A CDM4/19
PHILIPS CD-410 CDM12.1/05
PHILIPS CD-460 TDA1541 CDM2 //CDM4/25
PHILIPS CD-465 TDA1541
PHILIPS CD-470
PHILIPS CD-471 TDA1541 CDM4/11
PHILIPS CD-472 TDA1541 CDM4/11
PHILIPS CD-473 TDA1541 CDM4/11
PHILIPS CD-480/2 TDA1543 CDM4/19
PHILIPS CD-500/2 CDM4/19
PHILIPS CD-560 CDM2 //CDM4/25
PHILIPS CD-581/2 TDA1541 CDM4/19
PHILIPS CD-583/4 CDM4/19
PHILIPS CD-586 CDM4/19
PHILIPS CD-600/4/5 CDM4/19
PHILIPS CD-610 SAA7310 SAA7220P TDA1541 CDM4/19
PHILIPS CD-604 TDA1543 CDM4/19
PHILIPS CD-614/15 TDA1543 CDM4/19
PHILIPS CD-618 Bitstream ? CDM4/19
PHILIPS CD-620 TDA1541 ? CDM4/19
PHILIPS CD-621 SAA7345
PHILIPS CD-624 SAA7323 CDM4/19
PHILIPS CD-630 SAA7220P/B TDA1541 CDM4/19
PHILIPS CD-634 Bitstream ? CDM4/19
PHILIPS CD-640 TDA1541
PHILIPS CD-650 SAA7210 SAA7220P/A TDA1541 CDM2/29//CDM4/25
PHILIPS CD-660 CDM4/11
PHILIPS CD-670 SAA7210 SAA7220P/A TDA1541 CDM4/11//(69130212) LM833 slim size,
plastic case, SPDIF
PHILIPS CD-690 Bitstream ? RCD1.2D
PHILIPS CD-692 Bitstream ? CDM9/63
PHILIPS CD-710/720 CDM12.1/05
PHILIPS CD-723 SAA7378 TDA1545 VAM1201 NJM4560
PHILIPS CD-733/740 CDM12.1/05
PHILIPS CD-751 SAA7378 TDA1549 CDM12.1/05
PHILIPS CD-750 SAA7378 TDA1549 CDM12.1/05
PHILIPS CD-753 SAA7378 TDA1549 VAM1201 NJM4560
PHILIPS CD-771 CDM2-0500//CDM4/11
PHILIPS CD-780/1 CDM4/19
PHILIPS CD-782 TDA1541 CDM4/19
PHILIPS CD-820 SAA7220 TDA1541 A CDM4/19 LM833
PHILIPS CD-830 CDM4/19
PHILIPS CD-824/834 CDM4/19
PHILIPS CD-840 Bitstream CDM4/19
PHILIPS CD-850 TDA1541 CDM4/19 LM833
PHILIPS CD-880 TDA1541 S1 CDM1 mkII
PHILIPS CD-882 CDM1 mkII//691.20449
PHILIPS CD-883 CDM4/19
PHILIPS CD-910/11 SAA7341GP (4822-691-20768) CDM12.1/05//RCD1.2D
PHILIPS CD-930/1 TDA1547 CDM9/44
PHILIPS CD-920/1 CDM12.1/05//RCD1.2D
PHILIPS CD-940 CDM9/44
PHILIPS CD-950 TDA1547 CDM9/44
PHILIPS CD-950/1 TDA1547 CDM9/44
PHILIPS CD-960 TDA1541 CDM1/mkII ??? NE5534
PHILIPS LHH-100 TDA1547
PHILIPS LHH-500 TDA1547
PHILIPS LHH-600 TDA1547
PHILIPS LHH-800 TDA1547
PHILIPS LHH-1000 TDA1541
PHILIPS MAGNAVOX CDB-560 TDA1541
PHILIPS MAGNAVOX CDB-650 TDA1541
Model Decoder DF DAC Laser Unit An.Out Comments
PINK TRIANGLE NUMERAL TDA1305T
PIONEER DV-717 PE8001A
PIONEER PD40S PWY1010
PIONEER PD75 PD2028A
PIONEER PD93 PD2028A
PIONEER PD95 PD2028A
PIONEER PD-102/3 PEA1179
PIONEER PD-202/3 PEA1179
PIONEER PD-204 PD2026B
PIONEER PD-970 PEA1030
PIONEER PD-4050 PWY1010
PIONEER PD-4500 PCM1700 PEA1030
PIONEER PD-4700/5700/6500/67000/7700/8700 PEA1030
PIONEER PD-4550 PCM1700P PEA1030
PIONEER PD-5100 PD0034 PWY1010
PIONEER PD-52 PEA1030
PIONEER PD-5300 PCM56 PWY1010
PIONEER PD-54 PEA1179
PIONEER PD-5500 PEA1030
PIONEER PD-5050 PWY1010
PIONEER PD-5700 PD2026A PEA1030
PIONEER PD-6050/6100/6300 PWY1010
PIONEER PD-65/6500/6700 PEA1030
PIONEER PD-7050 PWY1010
PIONEER PD-7300 PCM58P
PIONEER PD-7300/7500/7700/8700 PEA1030
PIONEER PDR-04 AKM4321
PIONEER PDR-609 PCM1716
PIONEER PDR-W739 PCM1716
PIONEER PDR-W839 PCM1716
PIONEER PDS-06 PCM1702J
PIONEER PD-S303 PEA1030 NJM 4558/4580
PIONEER PD-S501 PEA1030 NJM 4558/4580
PIONEER PD-S502 PD2026B PEA1179 NJM 4558/4580
PIONEER PD-S503 PEA1179 NJM 4558/4580
PIONEER PD-S505 PD2029A PEA1030 NJM 4558/4580
PIONEER PD-S507 CXD2507aq PE8001A NJM 4558/4580
PIONEER PD-S602/3 PEA1179 NJM 4558/4580
PIONEER PD-S601/701 PEA1030 NJM 4558/4580
PIONEER PD-S702 PEA1179 NJM 4558/4580
PIONEER PD-S703 PD2029A PEA1179 NJM 4558/4580
PIONEER PD-S707 PEA1030 NJM 4558/4580
PIONEER PD-S801 PD2028
PIONEER PD-S802 PD0116A PEA1179
PIONEER PD-S901 PD2028B PEA1030
PIONEER PD-S909/990 PEA1030
PRIMARE D20 AKM4324
PRIMARE D302 4x PCM1702
PROCEED PCD2 PCM58P
PROTON AC423 LC78820
PROTON AC424 TDA1311A
QUAD66 TDA1541A
QUAD77 CS4328
REGA PLANET PCM1710U
REVOX B225 TDA1540
REVOX B226 TDA1541 NE5534
REVOX C221 SAA7310
ROKSAN ATTESSA DP3P CS4328
ROKSAN CASPIAN TDA1305
ROTEL RCD-02 PCM1732
ROTEL DCM-9PRO PCM63
ROTEL RCD-855 TDA1541 CDM4/19
ROTEL RCD-856BX SAA7323
ROTEL RCD-865BX SAA7323
ROTEL RCD-945AX SAA7341GP T
ROTEL RCD-955 TDA1541
ROTEL RCD-965BX SAA7323GP T
ROTEL RCD-970BX TDA1305T
ROTEL RCD-971 PCM63
ROTEL RCD-975 TDA1305T
ROTEL RCD-991 PCM63P
ROTEL RCD-1070 PCM1732
SANSUI CD V1000 PCM56
SANYO CP489 LC7881
SEG CD200 YM3020
SHARP DX112 IR 3K16BM
SHARP DX650 LC7880
SHERWOOD CD1 TDA1547
SHERWOOD CD1060C D6372 CX
SHERWOOD CD1160R PCM56
SHERWOOD CD1192R YM4113B
SHERWOOD CDC2000C μPD6376
SHERWOOD CDC2010RC μPD6376
SHERWOOD CD4030R SAA7350BS
SIMAUDIO MOON ECLIPSE 4x PCM1704K
SONIC FRONTIERS SFCD1 UltraAnalog D20400A
SONY CDP-25/356 KSS120C
SONY CDP-203/30/45/50/55/65/70 KSS121A
SONY CDP-40 1x PCM54
SONY CDP-101 CX20017
SONY CDP-222ES PCM56P J
SONY CDP-227ESD TDA1541
SONY CDP-228ESD PCM58P KSS151A
SONY CDP-302ES CX20152
SONY CDP-333ESA CXD2562
SONY CDP-333ESD TDA1541
SONY CDP-333ESJ CXD2562
SONY CDP-337ESD 2xTDA1541A
SONY CDP-497 CXD2561
SONY CDP-502 PCM54
SONY CDP-502ES CX20152
SONY CDP-552 PCM54
SONY CDP-553ESD PCM53JP-V K
SONY CDP-555ESA CXD2562
SONY CDP-555ESD TDA1541A
SONY CDP-555ESJ CXD2562
SONY CDP-620 CX23034 PCM54
SONY CDP-650 PCM54
SONY CDP-701ES CX20017
SONY CDP-777ESA CXD2562Q
SONY CDP-M18 CXD2500Q CXD2554M KSS240A
SONY CDP-MS1 CXD8594 + CXA8042AS
SONY CDP-R3 + DAS-R1a CXD2552Q + CXD2552
SONY CDP-X229ES CXD2562Q NKS240A
SONY CDP-X3000 CXD2562Q + CXA8042AS
SONY CDP-X303ES CXD2562Q
SONY CDP-X5000 CXD2515 CXD2562 + CXA8042
SONY CDP-X505ES CXD2562Q
SONY CDP-X33ES CXD2552Q
SONY CDP-X55ES CXD2552 KSS270A
SONY CDP-X777ES CXD2552BQ
SONY CDP-X779ES CXD2562
SONY CDP-X77ES CXD2552 KSS280A
SONY CDP-X7ESD PCM58P S KSS190A
SONY CDP-X900 CXA8042
SONY CDP-XA30ES CXD2562Q + CXA8042AS KSS160B
SONY CDP-XA50ES CXA8042AS
SONY CDP-XA55ES CXD8594Q + CXA8042S KSS310A
SONY CDP-XA5ES CXD2562Q + CXA8042AS
SONY CDP-XA7ES CXD2562 + CXA8042AS
SONY CDP-XB920 CXD8715 + CXA8355
SONY CDP-XB720E CXD8735N
SONY CDP-XB930 CXD8735N
SONY CDP-XE300 CXD8567
SONY CDP-XE330 CXD2529Q
SONY CDP-XE900 CXD8505 + CXA8055 KSS213B
SONY DAS-R1 4XTDA1541AS1 (single crown)
SONY CDX11/20/80/5B KSS160B
SONY CDXA15/20/30 KSS160B
SOUND WAVE CD1100 LC7881
SUDGEN OPTIMA TDA1543
SUDGEN SDA-1 TDA1541
SUDGEN SDT-1 TDA1541AS1 (single crown)
T+A CD1210R SM5864AP
TAG McLAREN CD20R CS4329
TALK ELECTRONICS THUNDER 3 CS4390
TASCAM CD201 MN6474
TEAC PD155mk2 Y3015
TEAC PD160 TC9218F 9A01026600
TEAC CPD3450SE YDC103LSI OPAxx
TEAC CPD3100/4100 KSS210A
TEAC PD365 YM7121B
TEAC VRDS 7 TDA1547
TEAC VRDS 8 PCM1702
TEAC VRDS 9 PCM1702
TEAC VRDS 10SE TDA1547
TEAC VRDS 25 AD1862J
TEAC ZD5000 PCM53
TECHNICS SL-P1 PCM53
TECHNICS SL-P2 PCM53
TECHNICS SL-P110 PCM54HP
TECHNICS SL-P120K E PCM54HP
TECHNICS SL-P272A MN6474
TECHNICS SL-P202/212/222 CDM4/19
TECHNICS SL-P177/277/377/477 A CDM4/19
TECHNICS SL-P1200 PCM54HP
TECHNICS SL-P360/70/460/70/570 CDM12.1/05
TECHNICS SL-PG480A MN662713 CDM12.1/05
TECHNICS SL-PG100/200/400/420/440/500/520/540 CDM4/19
TECHNICS SL-PJ28A MN6477 CDM4/19
TECHNICS SL-PJ24/26/27/28/37/325/46 CDM4/19
TECHNICS SL-PS620 CDM4/19
TECHNICS SL-PS670D MN6474 CDM12.1/05
TECHNICS SL-PS700 MN6474 SOAD70A
TECHNICS SL-PS740A CDM4/19
TECHNICS SL-PS770A MN6473 CDM12.1/05
TECHNICS SL-PS840/900A SOAD70A
THETA DSP PCM67
THOMSON LAD300 TD6720N
THULE CD100 CS4303
THULE SPIRIT PCM1715U
TOSHIBA XR40 TD6705AP
UHER UCD-210 LC7882
UNIVERSUM CD4682 PCM56
USHER CD-100 PCM1732
WADIA 850 PCM1702
WADIA 860 4x PCM1702
WADIA 861 4x PCM1704
YAMAHA CD-2 PCM53
YAMAHA CD-3 PCM53
YAMAHA CD-2000 PCM54HP
YAMAHA CDX-3 PCM54
YAMAHA CDX-410 PCM56
YAMAHA CDX-420 PCM56
YAMAHA CDX-450 KSS210A
YAMAHA CDX-470 YDC103 KSS210A
YAMAHA CDX-480 MN66271 KSS210A
YAMAHA CDX-490 MN66271R
YAMAHA CDX-580 YAC514 KSS210A
YAMAHA CDX-590 YAC514
YAMAHA CDX-593 YAC514
YAMAHA CDX-700 PCM56
YAMAHA CDX-750/860 KSS210A
YAMAHA CDX-880 YAC514 KSS210A
YAMAHA CDX-900 PCM56
YAMAHA CDX-890 YAC514
YAMAHA CDX-893 YAC514
YAMAHA CDX-993 YAC514F
YAMAHA CDX-1100 PCM56
YAMAHA CDX-2020 PCM58
