請教各位大大,PPA和M3改進成雙通道,具體改法是怎么樣的?
文章amb 發表於 週二 11月 13, 2007 6:45 pm
cklee 寫:I still doubt about how will the g-channel's response be when the both left/right channels want to draw high output current and exceed the g-channel's current supply limit.
Using single speed g-ch to supply double speed current(left channel + right channel)?
It's not a bottleneck if the current ratings of each of the channels are far above any practical limit. Don't forget that M³ and β22 have fast, high-current output MOSFETs rated at 17A+, and the σ22/σ11 power supplies are also capable of very high currents... No headphone load will draw anywhere near that much. Typical output currents are in the tens of milliamps. Even the little Mini³ (high performance edition) have very fast opamps capable of ~200mA output.
maxyeah 寫:could you give me your msn?
Sorry, I do not use MSN and don't usually use any IM service.
amb
註冊時間: 週日 6月 05, 2005 5:31 pm
來自: Sunnyvale, CA, USA
文章isas 發表於 週二 11月 13, 2007 10:06 pm
感謝AMB大的解答 :bow: :bow: :bow:
isas
註冊時間: 週三 6月 27, 2007 4:22 am
來自: 初心者村
上一頁
正在瀏覽這個版面的使用者:Bing [Bot] 和 43 位訪客
