Appraisal
I,_________________________(Please Print), hereby testify as an independent authenticator, that all of the damages claimed below are true and accurate after my physical inspection of this Tascam CD-401 unit with the serial number of “230303 913” manufactured by Teac Corporation Japan in July 1991.
This unit has a crack on one end of the CD transport, signs of tarnish on various locations including the transport itself and the chassis indicating possible physical abuse and lack of care in the past. I have tried playing Redbook standard CDs on this unit and this Tascam unit seems to report back with “NO DISC” for about half of the discs I tried to play, and on the few CDs that it plays, nominal vibrations transferred to this player can cause it to skip. This player also suffers the tendency of not being able to pick up signals from the exterior parts of most discs, resulting in loss of the last tracks.
Since the digital and analogue circuits seem to be in fair condition, I suspect of this problem to be caused by possibly the loss of adequate physical damping, and the malfunction of the Sony laser pickup system that this unit utilizes. The optic servo is in fine cosmetic condition, but I am certain that it does not function properly from the signs observed above.
As far as visible flaws go, this unit has numerous minor scratches on the top chassis, and a rather worn/tarnished bottom. There are noteworthy amounts of wear and rust on the stereo analogue RCA outputs, the digital RCA output, and the two XLR outputs; although the most significant rust build-up is found on the fader input jack.
The photographs enclosed should confirm and explain the damages claimed if not already covered.
Name of Inspector/Authenticator_________________________
Inspector/Authenticator Signature_________________________
Date of Inspection_________________________
Contact Number_________________________
小蔡 寫:kaylen 寫:小蔡 寫:kaylen 寫:DennyCho謝謝你的大恩大德,我人在台北中壢有點小遠啦
如果有確定要過去再跟您聯絡
我在三重.....如果有興趣....來吧
來參觀一下我的狗窩
只是我的 401 是一台很有個性 的機子.......
不只是燒錄片 連太廉價都不去讀
感謝,等我確定要去打擾再與您聯絡
來不及啦.....
我的401 去唐竹做客了.......
小蔡 寫:沒有啦....想要502是 要來組 第二套 音響....
CD-100 呀 我只能說....入門可以啦...難登大雅之堂.....
401 的表現........實在是小小投資.....大大的享受......不管是 類比輸出..還是數位......而且他電路乾淨...加上有 XLR 輸出
在這要 謝謝 JACKAL 兄......
正在瀏覽這個版面的使用者:沒有註冊會員 和 127 位訪客
