New your advices.
New your advices.
文章e4cu 發表於 週二 1月 27, 2009 8:25 am
Hi,
Sorry this is in English as I don't know how to key in Chineses but I can read Chinese.
I would like to get a better desktop stereo system for my computer so I can enjoy the music when I do my work home. So far, I have a pair of powered speakers from AudioEngine, Audioengine 2, http://www.audioengineusa.com/a2_home.php, which connects to Asus Xonar U1 Audio Station, http://www.asus.com.tw/products.aspx?l1=25&l2=147, connecting to PC via USB.
Well, the sound quality as we can expect is not that good. The bass seems to be a little too heavy and muggy. I am considering replacing Asus Xonar with KECES's DA-151. Can I do the following, PC -(USB)-> DA-151 -> A2 powered speakers?
Your advices are very much appreciated.
Regards,
Eric Lu
e4cu
註冊時間: 週二 1月 27, 2009 8:06 am
Re: New your advices.
文章autumnfall 發表於 週二 1月 27, 2009 8:46 am
e4cu 寫:Hi,
Regards,
Eric Lu
一開始看到一大串英文和兩個連結,以為是廣告機器人入侵 :hand:
DA151 -> A2可以用RCA TO RCA的線來接~
直接接上去就可以了,不過我只有聽過KECES UAB Ver1.2
算是DA151的前x代吧,用OP604的話,不會有BASS太重的問題,聲音略偏解析...
或許跟你的A2可以互補
新的DA151我就沒聽過了 :haha:
耳機 Sennheiser HD600
autumnfall
文章: 26
註冊時間: 週三 3月 05, 2003 9:44 am
來自: 蘆洲
文章jjj121 發表於 週二 1月 27, 2009 11:10 am
用DA151就要從電腦端調音量, 不太方便
照您的問題描述
換喇叭會是直接有效的方法
jjj121
註冊時間: 週日 9月 30, 2007 10:40 pm
文章Baimi 發表於 週三 1月 28, 2009 12:29 am
Care to state your budget?
Chances are, you would get a more apparent upgrade in terms of sonic performance by getting a new pair of speakers;
while it is true that the DAC/source you use makes a difference, the speakers you use will have a greater influence on the overall performance of your system.
Team HD800
Baimi
註冊時間: 週二 2月 26, 2008 12:38 pm
文章e4cu 發表於 週三 1月 28, 2009 3:28 am
Thank you all for your advices. Keep coming, please.
Regarding budget, I am OK to spend up to NT 20K for the USB based DAC and the powered speakers. The reasons I would like to replace USB based DAC are (1) according to review in "Stereophile", http://www.stereophile.com/standloudspeakers/1207ae/, Audioengine 2 seems to be a good choice for desktop; (2) when I connected my "HeadRoom Total BitHead", http://www.headphone.com/products/headp ... bile-line/, to Auidoengine 2, the bass sounds bad but "HeadRoom Total BitHead" with Sennheiser HD 595 works perfect. I realized that "HeadRoom Total BitHead" is an headphone amp which might compensate bass for headphone.
At the same time, the position of those speakers _MIGHT_ cause my problem too. As it is on the desktop and about 2 to 3 feet away from me as I sit and use computer. So, as the speakers and me are in a triangle with same length (2 to 3 feet) on each side, I might _NOT_ be able to have the speakers in enough volume (power) to work. I tried to sit back about 6 feet away from the speakers and have bigger volume, it sounds much better: bass is punch and solid. Looks like the speakers is not a real desktop one, in stead it is a bookshelf one, and I need to move speakers out of my desk to position them right. Gee, that would be too much trouble. Any advices/suggestions on this?
e4cu
文章J@ck 發表於 週六 1月 31, 2009 2:00 am
With a budget of ~$600 USD, you have a lot of choices.
The simple solution would be something like the Focal XS. Priced at $599 but you can find it online for $500 shipped within US.
Or the Axiom Audiobyte (They have 30-day in-home trial program.)
Or you can get an entry level audiophile setup, like the Cambridge 540A v2 amp or some used Creek/Rega/Naim/Arcam...etc with Ascend CBM 170SE/EPOS ELS3/PSB...etc.
If it's me, I might get a good 2A3 SET amp with a bookshelf speaker with 90+ sensitivity and a nice tweeter.
J@ck
文章: 17
註冊時間: 週日 3月 28, 2004 2:27 pm
文章jjj121 發表於 週六 1月 31, 2009 9:56 am
這台Focal XS看起來真不錯
PCHome網路購物賣29900, 真想聽看看
jjj121
文章e4cu 發表於 週六 1月 31, 2009 10:56 am
"Or the Axiom Audiobyte (They have 30-day in-home trial program.)"
Interested in checking out Axiom Audiobyte after visiting its web site, http://www.axiomaudio.com/. With 30 days trial and free shipment to States, definitely will do that.
Thanks.
e4cu
正在瀏覽這個版面的使用者:Majestic-12 [Bot] 和 26 位訪客
