sakura98249 寫:k@rogers 寫:我是1212光纖接到DAC-1,但我沒聽過USB版![]()
所以也很好奇
請問大大您1212接到DAC-1效果如何呢??
可以分享一下嗎?謝謝!!
sakura98249 寫:timchen1112 寫:Mac has optical output, why pay extra for usb? (your brother)
coax sounds a little better than usb, based on my experience.
don't waste your money
use the money to buy something else (e.g., save up for hd800)
我哥哥她是iMac和Macbook Pro,只有光纖輸出。
而且測試結果輸出能力實在有點差。(比USB差)
而且他當時也買得比較便宜。
所以大大比較推薦買張音效卡然後買DAC-1就好嗎?
樓上的大大蠻推薦USB的方便性的。實在難以選擇。
畢竟差了一萬啊!
Baimi 寫:USD$ 340 USB cable?
Did you get to test it out before shelling out the dough for it?
With cables that cost that much, did it ever occur to you that investing in a decent source (CDP/transport) might be a logical step to take?
Baimi 寫:What kind of set up are you using, if you don't mind me asking?
I would guess you have both your PC and CDP as your sources, which are all hooked up to your DAC1 Pre, which would make the most sense because it would be absurd for you to blow that money on a USB cable if you already knew DAC1 Pre's coax is superior to its USB in.
Also, 350 bucks as an introductory price is kinda steep, at least for me.
Anyway we should stop derailing the thread and let normal discussion continue
timchen1112 寫:i use a dac1 pre and i prefer the sound using coax iuput over that using usb input
i use a cheap (20 usd, used) philips dvd player's coax to feed the dac1 pre
the coax cable is 80 usd
the usb cable i use is 340 usd (locus design polestar) but coax still wins - the difference is small though
i have no experience with any sound cards however
but its nice and convenient to have usb input
jjj121 寫:timchen1112 寫:i use a dac1 pre and i prefer the sound using coax iuput over that using usb input
這...比較的基準不同吧
並不能代表dac1接電腦同軸/光纖比usb好
樓主是想要問電腦訊源
我也對這問題很有興趣
不過我是用筆電
這輩子大概也不會再買桌機了, 筆電省電安靜又方便
正在瀏覽這個版面的使用者:beatmania, Bing [Bot], Google [Bot], key840716 和 122 位訪客
