版主: devilhades
aeolusyung 寫:MP3基本上屬於破壞性壓縮,就算轉成WAVE也已經嚴重失真了(所以不能說是「轉回」)。
如果原先的WAVE檔已經不見,建議直接留MP3就好,不需再花心思轉檔了。
aeolusyung 寫::aa: 左右分離?好奇特的現象第一次聽到,水王大可以幫忙說明一下嗎?謝謝~
疾風殘月 寫:請問一下
用CPLAY播放時出現這個:
cPlay 2.0b20 (SSE2), licensed under GNU GPL
ASIO Technology by Steinberg Media Technologies GmbH
ASIO is a trademark and software of Steinberg Media Technologies GmbH
SRC (libsamplerate-0.1.5) licensed under GNU GPL
(see 'note *1' in specifications located in readme.txt for code changes done)
ASIO Driver Initializing...
Name (ALESIS IO|2 USB ASIO)
Player ASIO version (2)
Driver ASIO version (1)
Message (No ASIO Driver Error)
Channels (inputs: 2, outputs: 2)
Buffer details (min: 88, max: 880, preferred: 457, granularity: 1)
Sample rate ( 44100.0)
Output Ready? Not supported
Preparing buffers... successful
Latencies (input: 457, output: 4113)
Hardware supports additional optimization - enabled
ASIO Driver initialized.
DSP starting...
DSP Buffer (14624 samples or 331.6ms/ 3.0hz/ 96.5hz) allocation successful
ASIO Driver starting...
Input 1 [ Input ] Active (0) type (NOT SUPPORTED, type=17)
Input 2 [ Input ] Active (0) type (NOT SUPPORTED, type=17)
Output 1 [ Output ] Active (1) type (NOT SUPPORTED, type=17) > Left Channel
Output 2 [ Output ] Active (1) type (NOT SUPPORTED, type=17) > Right Channel
ASIO start FAILED. Only 32 bit ASIO format supported.
請問是出了什麼問題??
ASIO是ASIO Multimedia Setup
Mira 寫:ASIO start FAILED. Only 32 bit ASIO format supported.
疾風殘月 寫:Mira 寫:ASIO start FAILED. Only 32 bit ASIO format supported.
汗...IO|2只支援到24BIT
老吳 寫:老吳 寫:有SSD還需要RAMDISK嗎
答案:需要
aeolusyung 寫:老吳 寫:老吳 寫:有SSD還需要RAMDISK嗎
答案:需要
吳大有什麼深刻體驗嗎?不介意的話可否分享??謝謝~
老吳 寫:用Patriot 博帝 Solid State Disk 32GB 當作業系統,用foobar2000,APE轉FLAC,
效率差有時轉出的檔案不能用,把foobar2000資料夾放到RAMDISK就沒問題,速度又快
可能這顆SSD等級太差,不適合當作業系統
正在瀏覽這個版面的使用者:沒有註冊會員 和 17 位訪客
