轉一下其他各站看來的消息
http://www.tweekgeek.com/_e/Portable_Co ... erface.htmhttp://www.m2tech-hiface.com.au/index.php/newsm2tech hiFace Evo
clock in,I2S out規格與支援度完整的usb輸出入介面 365.00 美元
USB-to-S/PDIF interface, based on the same technology as hiFace, but with many improvements. Hosted in a stylish brushed aluminum case (105 x 100 x 46mm), with B-type female USB connector.
Main features
input for external supply (7 to 11VDC)
input for external Master Clock (BNC with transformer)
2 x S/PDIF outputs (RCA and 75 Ohms BNC)
AES/EBU output with XLR connector and settable format (consumer and professional) by an internal jumper
Toslink output
ST output
direct I2S output with 3.3V interface.
Some customers complained because of the lack of sampling frequency encoding in the S/PDIF stream of the present hiFace. The new model will have this fixed, for full compliance with the standard.
All outputs (except I2S) are transformer-decoupled to avoid ground noise and EMI interference. Three LED's indicate power, data stream in input and external clock presence.
Young 384/32 USB DAC
384/32 USB DAC 不知有無asynchronous USB?不然又更吸引人 969美元
Stereo D-to-A converter in a nice brushed aluminum case and grilled front panel measuring 200 x 50 x 200 mm. Some of the highlights of this new model include:
input sampling frequencies (kHz): 44.1, 48, 88.2, 96, 176.4, 192, 352.8*, 384* (* USB only)
resolution: up to 32 bits (USB), up to 24 bits (other inputs)
inputs: USB (B-type female), S/PDIF (RCA and 75 Ohms BNC), AES/EBU (XLR), Toslink
outputs: single-ended on RCA
supply: external 9 to 24VDC
controls and display: standby, source select, large matrix display to show locked frequency and selected input
Vaughan 384/32 Reference USB DAC
m2tech 最高階dac 有clock in 耳擴功能 6029美元
384/32 Reference USB DAC and Preamp
M2Tech's first Stereo D-to-A converter is finished in a nice brushed aluminum chassis and unique front panel
From the manufacturer that transformed computer audio with the hiFace, the Vaughan DAC seeks to move the state of the art forward aggressively. with the potential for streaming 384 kHz / 32 bit files, the Vaughan DAC is already set for future formats.
Vaughan DAC features:
Input sampling frequencies (kHz): 44.1, 48, 88.2, 96, 176.4, 192, 352.8, 384
Resolution: up to 32 bits (USB), up to 24 bits (other inputs)
Inputs: USB (B-type female), S/PDIF (2 x RCA and 2 x 75 Ohms BNC, dual AES for 384kHz), AES/EBU (2 x XLR dual AES for 384kHz), Toslink (2 x for dual AES), ST (2 x for dual AES), straight I2S, external master clock
Outputs: single-ended on RCA and balanced XLR, plus a headphone ouput on 6.35mm jack socket
Power supply: 115-230VAC, optional high current lythium battery with battery changer available
Controls and display: standby and select buttons, encoder, dual large matrix display to show locked frequency and selected input.
The Vaughan features 8 D/A IC's (4 per channel in mono mode). A digital dithered volume control will allow for using the Vaughan as a preamplifier. The headphone output is made with a discrete components amplifier.
Brushed aluminum case and grilled front panel
Dimensions: 440 x 80 x 440 mm.
